your remote should have channel scan on it if not go to the menu on the TV and it should have channel scan on that or you could just push the number 3 on your remote for the channel!
You will need to re-scan the channels, i don 't know where it is on the menu of this set. If you are on cable, you need to make sure your tv is set to cable tuning, or you cannot get channels past channel 13. Same is true for antenna if you are on antenna make sure you are set for this.
disconnect the cabel of left channel from your amp disconnect the cabel of right channel and put it in place of left channel if the problem goen your problem is in left speaker itself (cabel or speaker).if the problem excit the problem will be in amplifier output stage
Usually caused be a secondary device. If you guys have a cable box try this test. Unplug the coax cable from the back of the cable box. plug the coax cable from the wall directly to the TV and do a chennel scan. See if the probelm is still there. If it is TV needs service. If it is gone...it is your cable box. Call the cable company. If you have Satelite all you can do to test it is try another device and see if you have the same problem. A dvd player, VCR, game console etc. and see if the problem happends with that as well. If it does then the TV needs service.
already tried that it did not work
