20 Most Recent
Sharp VC-A582U VCR Questions & Answers
WOULD LIKE A USER MANUAL FOR A SHARP VC-A582U
It depends what you are recording from. Most newer tv broadcast will block the recording by injecting copyright code into the stream. It forces you to get a dvr system from the company like cable or satellite. Because of the new digital broadcast it makes over the air recording to vhs difficult. More for the fact that you have to hook a converter box to the vcr to get the signal from digital to analog again. Here is the link to the manual.
http://archivos.diagramas.mx/otros/VCA582U.pdf
Would like to tape from tv.
this should help jar your memory some....if your vcr is set/tuned to ch 3...and tv is set to ch 3....cable/dish box is your ch selector (tune to any ch u wish) put a blank tape in press record if you want to record....(you are not home, you must set the timer on the vcr /menu/timer recording settings)...make sure the cable box is set to the ch you wish to record...or else you will miss your recording you want.
VCR won't record.
When you press record, does the tape eject? if it does, make sure the safety tab is intact. if not, put a piece of scotch tape over the hole.
Do you hit the record button on the vcr or a universal remote? On a remote, you may have to hit recort 2 times.
I need the codes for the remote to program it to
There are two devices that need to be identified; the remote brand and model and the VCR brand and model.
Giving us only one is useless.
Secondly, there may not be any code set in the remote compatible with your VCR.
Universal remotes aren't universal.
Channels
Sometimes the RC [remote control] has a MENU button that you can "bypass" any channel.Did you use the RC and 'delete' the channels by mistake?
How do I operate Sharp LCD TV remote control
First of all
1. **Power On/Off:** Use the "Power" button.
2. **Changing Channels:** Use "Channel Up" and "Channel Down."
3. **Adjusting Volume:** Use "Volume Up" and "Volume Down."
4. **Input Selection:** Use "Input" or "Source" to choose input devices.
5. **Navigating Menus:** Use navigation arrows and "Enter" or "OK."
6. **Mute Function:** Use the "Mute" button.
7. **Number Pad:** Input channel numbers or perform numeric functions.
8. **Special Functions:** Access features like "Menu," "Exit," "Subtitle," or "Info."
9. **Teletext/Closed Captioning:** Access these features if applicable.
10. **Smart TV Features:** Access smart features, apps, or online content if applicable.
11. **Batteries:** Ensure the remote has fresh batteries for responsiveness.
For model-specific details, always refer to your Sharp TV's user manual. If you provide your TV's model number, I can offer more tailored instructions.
Changing analog to digital on Sharp TV
Unfortunately, you cannot convert an analog TV to digital simply by changing settings. The transition from analog to digital involves hardware changes. If you have an older Sharp TV without a built-in digital tuner, you may need an external digital converter box or consider upgrading to a newer TV with a built-in digital tuner to receive digital broadcasts.
Sharp DVD player not working?
the reason as to why your sharp dvd player isn't working is because there may be a disk stuck inside, try pressing the STOP button, unplug it, press EJECT while plugging it
