Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
Posted on Jul 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer sees belkin 54g, shows all bars, when
HP Pavilion dv6226us computer sees belkin 54g, shows all bars, when tries to connect says it has low signal and cannot connect. I have tried everything as I am pretty good with computers. Last night I even went to the router page and logged in. I checked everything. I changed the SSID but nothing else. I've dropped the firewall. The computer was connecting wirelessly until 5 July 09.
HP Touchscreen iq770 was working fine with my wireless HP Officejet 7700 until 6 July. Now I cannot connect to it either.
I have reset and rebooted the router.
I have shutdown the whole network, in sequence, waited 30 seconds and brought it back up in sequence.
I have reset the bios on both computers.
I have reloaded the printer software on the Touchsmart.
My only option is that it is the router.
Anonymous
Level 3:
  • Master 742 Answers
  • Posted on Jul 10, 2009
Anonymous
Master
Level 3:
Answers
742
Questions
0
Helped
193900
Points
2315
Make sure that your router is set for an "encryption system" that is similar to all your computers and mobile devices. Example, if your router is set to encrypt using WAP2, make sure all your devices connect and is capable to connect using WAP2. Or else, set it to WAP and set your devices to WAP also.
Regards!
Where can i find video driver for hp pavilion dv6226us
Go to HP site-Support&Downloads-enter model number-download what you need.
My Sony Vaio employs a wireless connection to a Belkin 54g router. Problem free for months but for last few weeks it will not connect automatically showing "windows cannot connect to Belkin 54g". Will...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Cant connect belkin 54g router to internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Click Here for more information
2answers
Cannot connect to wireless printer, pc is connected to 54g direct
its a bit complicated but we can try out.find out the ip address of teh wireless router,,put it in the address bar and click entera box will com for a username and a passwrd.if u havnt chaged anything.then default username and passwrd is{Belkin
IP : 192.168.2.1
username : admin
Password : (Blank)
try this and u will see a belkin page,,search for connected devices and u will see the printer option there.in the mean time install the drivers of the wireless printers on the desktop pc,,follow the prompts on the installation very carefully,,its easy and then make ita s a default printer,thats it
I have tried to install router strait from modem to router to toshiba l30 laptop belkin shows up on laptop showing excellent signal but when i try to go on web it cannot make contact
access your routers administration by right clicking your network icon and using your gateway IP to access http://*gateway*
un - admin pw - (none), admin, public
look at your status in the belkin administration settings and see if you have an ip and gateway for your ISP.  The ip and gatway on your computer is for your belkin.
Try directly connecting the laptop to the router with a cable and see if it's on the net. If it is then you have wireless settings wrong. See belkin.com for more infor about router.
James Mac
Cant connect
Hi! Did you go into the router configuration through IE (Internet Explorer)?
3answers
Wireless Internet Connection
Are the wireless router connected to a network?
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
