Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in
the foreground is exposed properly. My guess is that the background is
being lit by another light source. Typically, your camera uses a flash
for dark areas or what it gauges as a dark area. This doesn't adjust
the background for additional light sources. For example, if you're
standing outside and there's a tree covering someone that you're taking
a picture of your flash will adjust to "properly" light that
individual. However, because the flash was used for the main subject,
the background is actually now overexposed. The overexposed background
will show up as a brightly lit area because the camera had to adjust
for the foreground. This will actually reverse itself when it's dark
out - meaning if the background and foreground are dark, the flash will
expose the foreground, but the background will be black. Hopefully,
that helps you understand lighting and exposure. Now, to fix this
problem when shooting, you would need to consider several options - 1.
SLR camera with aperture and f-stop settings as well as compensation
controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using
a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
