Dishwashers Logo
Posted on Apr 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jenn-air dishwasher will not start
Model JDB1090AWS Jenn-air dishwasher touch panel seemed to have some of the lights burned out but the dishwasher ran fine. Now several months later the dishwasher will not start run. Is the problem with the touch panel (part# 6-919765)or with the control board (part# Maytag 6918612 Rev. C)?
  • spankyII Apr 18, 2015
    Replaced the control panel with Jenn Air Part #6-919765 and now it works great.
Level 3:
  • Jenn-Air Master 19,187 Answers
  • Posted on Apr 18, 2015
Jenn-Air Master
Level 3:
Answers
19187
Questions
0
Helped
4346514
Points
82261
It is usually the panel that fails
5 Related Answers
WJerryF
  • Posted on Jun 03, 2008
SOURCE: I need a wiring diagram for my Jenn-air dishwasher
I removed the circuit board and reinstalled it.
Now is works fine. Bad connection, I guess.
Anonymous
  • 132 Answers
  • Posted on Mar 30, 2009
SOURCE: maytag dishwasher MDBH940AWW. ''Touch Panel'' is not working.
Hi There,
Try just replacing the Keypad. It is cheap and is usually the cause. Hope this helps and thank you for using FixYa!
Anonymous
  • Posted on May 19, 2009
SOURCE: jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Bill Johnson
  • 306 Answers
  • Posted on Jul 15, 2009
SOURCE: My Jenn-Air dishwasher has sprung a door leak! :-(
it's just a door gasket,you might still find it a appliance repair place.
Anonymous
  • 2468 Answers
  • Posted on Nov 26, 2010
SOURCE: DOES JENN AIR HAVE A REST BUTTON, MY DISHWASHER
first of all if its a built in dishwasher under counter by the sink,check for a switch as you may have inadvertentally switched this switch off or unknowingly bumped it with something under the sink,then if it has power to the unit,there is a built in fuse on the control board
Dishwasher will only run in the china cycle. All other options will not light up the green light.
Replace it depending on how old it is, or unplug for a few hours sometimes this will reset it, hope this helps.
Where is food trap located on Jenn-Air ?
Seems like every brand is different but generally speaking, the food trap is located under the main cleaning jet in the bottom of the tub. The part with the nozzles should just pull straight up and allow you to get at the food trap.
Jenn-air dishwasher jdb1090aws wont drain
Most common issue on this model is the drain motor itself. More times then not it gets clogged with debris. Pull the unit out and remove the three screws that mount the pump to the bottom of the dw.
take the hoses off and clean the drain motor out. It will fix this issue I have seen it more times then you could imagine. Good luck with your repair friend
My dishwasher will not start. I can chose my settings close the door and press start but it will not start.
You have a bad control panel. Here is your part#99003139
  1. Unplug your dishwasher
  2. Unscrew the the screws that run along side the inner door *don't let door drop*
  3. Unplug the ribbon cable and replace the control panel
This would only take 20min to change. Have a great day!
I have a Jenn-Air Dishwasher and it is leaving small pieces of food on my dishes on the top and bottom rack
There are various reasons for this incomplete wash. Please find the possible troubleshooting steps in the bellow mentioned article:
http://www.partselect.com/dishwasher+dishes-not-clean+repair.htm
Thanks
6helpful
3answers
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Smell in a new dishwasher
run bleach through it. if your on well water then this will happen often
Jenn-air Dishwasher won't drain water from base
This happened to me after installation. they had installed a one way valve backwards in the drain line and had to reverse it.
3helpful
Dishwahser won't start, start button won't light
I took the door apart, removed the control board, which I had expected to replace. I disconnected the ribbon cable that connects the control panel to control board cleaned the connections and reassembled everything. The dishwasher has been working since.
Top Jenn-Air Dishwashers Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
