I have fan failure. It has been making a strange noise for a week now. The noise is now gone but I have a "fan failure" notice when I boot up!
You need to replace the CPU fan as it has failed, I recommend that you refrain from using the computer until you have replaced the fan, this is because it has no way of cooling down and you will be running the risk of blowing the processor and/or the motherboard up.
The CPU fan is located inside the case and is attached to the motherboard on top of the processor.
Regards.
First you must determine which fan it is. open the side of the tower and turn on pc. watch which fan is mot rotating. i've seen cases where cpu fans don't turn because of wires getting in the way of fan blades.
if this is not the case, once you determine which fan is not working, just turn off pc, remove the fan, go to PC store and replace
This is probably because the fan has most likely 'died'. I would replace the fan because you don't what your computer to start to freeze up, overheat etc...
