Washing Machines Logo
Maher mghamis Posted on Mar 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have automatic hitachi washing mashine 110Q it has an error f9 what does it mean plz?
D. E. Hev
Level 3:
Genius:
  • Master 1,187 Answers
  • Posted on Mar 26, 2015
D.  E.  Hev
Master
Level 3:
Genius:
Answers
1187
Questions
Helped
424879
Points
5819
"F09" is an Overflow Condition error. The following link explains how to diagnose the problem yourself:
http://www.fixya.com/support/r3608557-f09_error_code
Read through the information provided and check all the common sense things that you can easily eliminate, first. For more in-depth troubleshooting procedures, refer to the tech sheet that came with your washer. The tech sheet is located inside your appliance. To access, remove the lower toe panel under the door by removing the screws under the bottom front edge (you may have to prop the two front feet of the washer up for better access - a 2x4 works well for this). With the screws removed, the panel will drop down, then come off.
The tech sheet will either be located directly behind the toe panel, or affixed to one of the interior cabinet walls. The tech sheet includes troubleshooting tips, error code definitions, test points, diagnostics procedures and wiring diagrams. You will need to use the tech sheet to accurately locate and perform some of the steps I have outlined. F09 Error Code Fixya
4 Related Answers
kapishtech
raj somaiya
  • 2272 Answers
  • Posted on Aug 11, 2010
SOURCE: washing mashin is writing error LE what does it mean?
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Anonymous
  • 15935 Answers
  • Posted on Sep 15, 2010
SOURCE: hotpoint Aquarius+ WF740 washing mashine flashing F-05s
  • F05 - Pressure switch jammed on full
  • The pressure switch must be changed.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Anonymous
    • Posted on Dec 19, 2010
    SOURCE: Hitachi washing machine. Model:SF-P90DJ Fault code F9
    my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
    Anonymous
    • 6277 Answers
    • Posted on May 07, 2011
    SOURCE: my machine i Could not
    (no promises but try this!)
    I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
    Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
    If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
    REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
    It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
    Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
    At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
    If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Hitachi washing machines SF-95FJ has a C2 error
    My hitachi sf- 85p js is washing machine cleck c2,c3, warning stop f9?
    1helpful
    Hitachi washing machine model SF-150GJX showing error F9. Any one knows what this means?
    My washing machine hitachi SF-110LJS showing F9 ERROR
    PLEASE HELP URGENT
    3helpful
    2answers
    Model:SF-95CJ F9 FAULT CODE
    my hitachi model SF-95 CJ is washing machine show F6 ,C4, F4 FAULT CODEcleck
    4helpful
    5answers
    Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
    if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
    mail me if yours working I will give you more tips [email protected] cheers
    68helpful
    5answers
    Model no wa80b3 samsung washing mashine
    My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
    Top Washing Machines Experts
    john h
