I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
Check pump for blockage
Hi friend, thank you for your inquiry!
On an Electrolux washer the error code "E00" stands for No code stored. This could be a miscommunication I would recommend you perform a reset on your washer. You can do this by flipping the household breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E00". I look forward to assisting you. -Matt
Hello - I am happy to assist you. However, are you certain that the error code is E33? From my research this manufacturer does not have an E33 error code for any of their units. Could it possibly be E32 or E35? If so, it is related to a pressure sensor issue. Either it has detected a pressure senor calibration error or an overfill water pressure sensor problem. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart washer. If it proved to be ineffective, contact a professional to properly diagnosis the unit and move forward accurately.
