Will notload software-needs installer but will not load software for microsoft 4.5 installer. can not install winrar from original disk that came with netbook
SOURCE: MSI wind U100 built in webcam
Try to press FN key together with F6 to makes the webcam works
SOURCE: how to activate webcam (msi U100)
you can activate that msi wind u 100 webcam when it is being installed on your system. You will be needing a driver installation source in order to use the device. the reason why you need these drivers, its because it allows the device to be recognized by the operating system .
you can download drivers for free at the manufacturers website.. :)
Hope this will help you out..
Pm me with your operating system and the model of your webcam if you want me to download the drivers for you..
Thank you :)
SOURCE: built in webcam not working MSI wind notebook u100 series
please chek ur webcam status..that on or off. if off press fn + f6.
SOURCE: built in webcamera driver for msi u100
Hello.
Your problem is not the drivers. The msi u100 webcam is supported by the operating system without the need for installing drivers for it.
Instead, turn it on by pressing and holding the Fn key (bottom left corner) and then pressing F6.
Cheers
SOURCE: u100 msi wind netbook, webcam problems
i have same problem pls sant driver u100 webcam [email protected]
