Electronics - Others Logo
Posted on Oct 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to make a 3.2 digital photo viewer work with Windows Vista. Computor says software was sucessfuly loaded. When viewer is plugged into usb port I get a window to import sample pictures from viewer to computor. When I click on the Photo Viewer icon it says Photo Album device was not found. What is the problem?
David Tickner
Level 2:
Sergeant:
  • Expert 159 Answers
  • Posted on Oct 30, 2017
David Tickner
Expert
Level 2:
Sergeant:
Answers
159
Questions
Helped
66849
Points
539
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Dec 23, 2007
SOURCE: help with the product
its possible you might of accidently put the wrong format type. Its happened to me before. Dont rate me badly though im not a wiz with cameras. Hope it helped :] .
Alun Cox
  • 2679 Answers
  • Posted on Aug 21, 2009
SOURCE: key chain photo viewer neds formatting
It is more than likely but not guaranteed that your pc is looking at it as a USB disc storage drive.
HP have a free format tool for these which I've used sucessfully in the past for pen/flash drives it's available here
http://en.kioskea.net/telecharger/telecharger-127-hp-usb-disk-storage-format-tool
Although not guaranteed to work I can only go from my experience using it and that of others.
Use at own risk.
Florin
  • 733 Answers
  • Posted on Dec 18, 2009
SOURCE: I need a download for the Digital Photo Ornament.
you can download it from this site http://software.informer.com/getfree-photo-viewer-2.3-c/ instal it and your done.
Anonymous
  • 1738 Answers
  • Posted on Dec 26, 2009
SOURCE: Portable Photo Viewer vs Windows 7
Computer Drivers
On computer driver, if you lost your cd drive disc or broke the cd you can download them by doing the following steps:
1. Go to your manufactor's website.
2. There should be a search bar on the top of there website.
3. click in the search bar and enter your model number of the
computer or you can enter hardware model.
4. After you hit you come accross to technical support page click on
that.
5. There should be a word pertaining drivers click on that.
6. Finally, click download and download the correct version of driver for
your windows.
vanessa113
  • 3 Answers
  • Posted on Dec 27, 2009
SOURCE: Photo viewer device not found
I got a key ring for Christmas too ...when the keyring is on 'charge' mode it doesnt show on computer ...you have to remove the lead from key ring, switch off key ring then replace lead and switch to 'update' mode. Now if you double click on icon it should work!!!
Testimonial: "Yay! You're spot on. Otherwise a good keyring - but not really clear for the novice user!"
1helpful
2answers
4answers
Digital photo album - keychain
The message "No Photo Viewer Found, program termined" will happen unless you have the keychain plugged into the USB port in syncronization mode not charging mode. It's just saying it can't find a Photo Viewer plugged in to sync with. That should solve your problems. You can't update you image library unless it is plugged in
Regards
Balisonu79
2helpful
4answers
I have installed the disk "dolphin 1.5" Digital Photo Frame with key chain (photo viewer V208G2 and am unable to get the thing installed. I run Windows Vista
s.wingard,
Are you sure the Dolphin Digital Photo Frame is compatible with Windows Vista? When I searched, all I saw that was supported was XP and 2000. Once drivers are installed and they do not work, it's best to uninstall the driver (in the control panel in the system hardware configurations). Delete the driver and restart the computer with the picture fram plugged into the USB. You should be asked if you want to install the drivers. You then pick the custom location for drivers and browse to your drive with CD. You should be able to find the drivers somewhere within the disk (usually contained in it respective OS Folder e.g. WINXP). Load that particular driver.
Hope this helps,
Bill
21helpful
5answers
Software won't install coby photo viewer key chain
You need to make sure the usb cable is in all the way to the viewer. You have to push it hard. No silver showing. Always need the viewer plugged in first before starting the viewer program. After that it is pretty simple.
5helpful
5answers
Coby Digital Photo Keychain DPKEY
Getting Started- VERSION DPKEY and 151SX
STEP-1
-INSTALL The Photo Viewer Software
Download & Install The Photo Viewer Software From Our Web Site:
The Driver CD files (Setup Guide, Manual and Photo Viewer Software) can be downloaded from
our web site. Click on the link below
http://www.cobyusa.com/?p=prod&prod_num_id=80&pcat_id=3001
NOTE:
Find your Photo Key Chain version and Download the Driver CD files along with all the latest
updates.
The version is listed on the back of the Photo Key Chain as 151SX, DPKEY or 151MP.
To Download & Install The Photo Viewer Software From Our
Web Site:
a) Create a folder
on your desktop before downloading the file from our website. To create
a folder on your desktop, go to your desktop and RIGHT click on your mouse. A set of
menus will appear. Select “New” and then “Folder” (you will notice a new folder will
appear on your desktop), give it a name, example DP151.
b) Click on the below link and select “Download”.
c) Click on your Photo Key Chain Version to start the Download. The version is listed on the
back of the Photo Key Chain (151SX, DPKEY or 151MP.
d)
After clicking on your version, you will prompt with a pop-up screen “Do you want to save
or open the file”. Select Save.
e) Another screen will prompt you to save the file on your computer. Save the file on your
“Desktop”, in the “DP151” folder and select “Save”.
f)
Once the download is completed, go to your desktop. Double-click on the DP151 folder.
g) To install the Photo Viewer software, Double-click on the Setup.exe file. Click NEXT on
all prompts.
h) After the installation. The Photo Viewer Software icon will appear on your desktop.
i) Done! ……Continue with “STEP- 2
STEP-2 CONNECT the Key Chain to your computer using the supplied USB cable. Upon
connecting the Key Chain to your computer, the Key Chain will prompt you to set the
device to “USB Charge or USB Update”. Select USB Update by pressing the Right
button and then the Middle button.
STEP-3 RUN the Photo Viewer Software to transfer photos to the Key Chain. Double-click on
the Photo Viewer icon located on your desktop. Once the Photo Viewer opens, it will
give you a message indicating “Upload Completed”. Click OK. (This message
indicated that the Photo Viewer Software has made connection with the Key Chain). If
you have received the “Upload Completed” Message, Skip STEP-4 and continue with
STEP-5
STEP-4 If you have NOT received the “Upload Completed” message, then you are
encountering the below error message:
Can’t Find any Photo Viewer, or
another program owns it. The
program will exit!
*Set the Photo Key Chain to USB update. SEE “STEP- 2”.
*Make sure the USB Cable is connected properly, you should hear a “clicking”
sound when the USB Cable is connected properly in the USB Port.
*The Key Chain should also appear under “MY COMPUTER” as a removable
disk. If not, switch the USB Port or replace the USB Cable.
STEP-5 LOCATE the images on your computer (See Diagram)
STEP-6 HIGHLIGHT the images files that will be transferred to the Key Chain (See
Diagram)
STEP-7 SEND the highlighted images to the Device Panel (See Diagram)
STEP-8 TRANSFER the images from the Collection panel to the Key Chain (See Diagram)
Disconnect the Key Chain from your computer. Done!
My copy of Photo Viewer came on the provided disk. Run set up to load it (if you do not have a disk go to the key ring manufacturers website). When you use Photo Viewer make sure that your key ring is attached to a USB port prior to starting the programme otherwise it will not load.
Cannot load concord camera Eye-Q Duo 2000 Software
i jus plugged mine into usb port and it downloaded the drivers for me without using mah disc at all...
Photo keychain
If this is like my keychain photo viewer you need to put the keychain in USB update mode before it will work.  When you first plug it in to the USB port it will show USB Charge or USB Update. Use the arrow keys to put it in USB Update mode and then press the menu power button.
At this point you can open the software and start adding photos!
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
