I also had the same problems in my laptop, but I had tried many ways, this problems couldn't be fixed. A friend told me maybe I need to reintalled the system. However, I didn't want to do. Finally, I tried to use other wifi software. A program named OSToto Hotspot can run. You can have a try! http://www.drivethelife.com/free-wifi-hotspot-creator.html
Dexel Bruno,
To turn the wireless on you would press FN+F2 or F2. The link below refers to the MS Virtual wifi error 31. http://bit.ly/1IXELU1
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Go into the Wii Menu (Wii icon on the main menu screen.
Select "Wii Settings," then "Internet," and "Connection Settings."
Erase your existing Internet Connection Settings and set up a new connection. (Click here for help)
Once you have established and tested a successful connection test, try the connection to the Wii Shop again.
If you have verified that your Wii console's internet connection is working, then there could be a temporary issue with the Wii Shop Channel. Please wait awhile and your connection again.
If you have tried the above troubleshooting and are still receiving this error code, please call us 1-800-255-3700 so that they may assist you further.
Go to Run, type in Cmd, Type in Ipconfig/all and if there is nothing there, then right click on your wifi applet select the repair function and it will try to repair the Ip Address
yes but you will need to download a wifi driver in the Dell so that it can communicate with the wifi service provider
best download the driver from the modem used for the connection
The error code 51330 means that the WiFi cannot get through to your Wii because of the security system you currently have installed on your router. WEP encrypted WiFi routers cannot connect with your Wii properly. To save you some time, I've found the exact link where Nintendo troubleshooting gives you detailed instructions in fixing this problem and getting your Wii to connect to your WiFi.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Cheers!
Use System Restore to revert device drivers and registry configurations back to a state previous to the Code 31 error. Be sure to choose a restore point from a date and time before you know or suspect that the Code 31 error first appeared. 8. Disable any hardware-based security on the device.
