Try following the steps below. Step 1 Press the power button once. If the TV does not turn on, observe the LED indicator, usually located on the TV's lower front panel. If the LED indicator turned off after you pressed the power button once, it is in standby mode. Press the power button once again to exit standby and turn on the TV.
Step 2 Observe the Standby light if the remote control will not work. If the Standby light stays on, the television is in Standby mode. Press the power button on the television, then try to use the remote.
Step 3 Turn the Energy Saving Switch off, then press the power button. The Energy Saving Switch is located on the rear or side panel on most Sony model TVs. Refer to your TV user manual for the exact location of the switch.
hi Shaun. How do I get my TV out of standby mode?
Press the power button once. If the TV does not turn on, observe the LED indicator, usually located on the TV's lower front panel. If the LED indicator turned off after you pressed the power button once, it is in standby mode. Press the power button once again to exit standby and turn on the TV.31 Mar 2015
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
I only have two solutions. Either, turn the tv on from the tv. or try checking the tv connection. If that doesnt work maybe the remote is out of battery.
Hi, How to Enter Service Mode 1. Turn on the main power switch to place this set in standby mode. (LED will light in red.) 2. Press the buttons on the commander as follows, and enter service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode 1. Set the standby mode (Press “ (TV STANDBY)” button on the commander), then press “ (TV STANDBY)” button again, hereupon it becomes TV mode.
