Sew D'Lite Lightweight Portable Mechanical Sewing Machine Logo
A
Anonymous Posted on Feb 15, 2015
How toThread sew D'Lite supreme machine
Don't know path of thread bobbin to top of machine
William Gilbert
Level 3:
Master:
  • Sew D'Lite Master 470 Answers
  • Posted on Feb 15, 2015
William Gilbert
Sew D'Lite Master
Level 3:
Master:
Answers
470
Questions
0
Helped
115927
Points
2377
They don't come with a manual. A very inexpensive machine.
1helpful
Bernina sewing machine 1630.. Stitch won't stay in. Bobbin thread pulls out ???
Clip the top thread next to the spool. Raise the presser foot and pull the clipped thread DOWN through the needle eye. (Always remove the top thread in this manner. NEVER pull the top thread up!!!)
Now, ALWAYS RAISE the presser foot and rethread the top thread. Verify the thread path is correct.
Set the top tension to the midway point (then tweak the tension by testing).
If the bobbin thread is still pulling out, the top thread tension needs to be tightened. The tension is correct when the top thread and bobbin thread meet in the middle of the fabric.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
1helpful
Bobbin thread just pulls through. St itch looks fine, but the bobbin thread pulls right through?? I have tried a couple different bobbin cases, all supposedly for the 1630???
Not sure, but it sounds like the top thread may not be seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Set the top tension to the midway point and test your stitch. Then tweak the tension.
1helpful
This is on a 5.0 pfaff sewing it will build a bird nest below the plate
Set the top tension to the midway point (may need to tweak this for your particular machine).
Remove the bobbin thread from the machine. Reinstall the bobbin in the bobbin case confirming the bobbin is turning the correct direction and the bobbin case is correctly threaded.
Pull the bobbin thread up to the top of the fabric and gently hold both thread tails in your left hand when slowly taking the first couple of stitches.
Bobbin issues the bobbin thread is bunching up
Check whether it is bobbin thread or the top thread accumulating under the fabric. Generally, if thread problems exist "under" the fabric, it is a top thread issue. If the problems exist "above" the fabric, it is a bobbin issue.
Sounds like a thread nesting (bird nesting) problem where the top thread is globbing under the fabric. Usually, this is caused by misthreading (confirm the thread path), the thread not seated in the tension disk (ALWAYS RAISE the presser foot when threading!), or very loose top thread tension.
Remove the thread. Raise the presser foot and rethread from the beginning. Check that the thread path is correct. Set the upper tension at the midway point between high & low numbers (this is the beginning point for tension and will most likely need to be tweaked for your particular machine).
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
3helpful
2answers
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
1helpful
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: http://www.singerco.com/uploads/download/705_white-338-x.pdf .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
I cannot seem to get the tention right, the threats pulls the material very badly and it is very tight
Is this a new machine, old machine, serviced recently??
Here is my regular checklist for stitching issues:
Change the needle and pick the right size for the fabric you are sewing, or ball point for stretch fabrics.
What thread are you using? good quality cotton wrapped polyester is good, Sylko Supreme, Metrosene, or Gutermann are all good brands.
Wind a fresh bobbin and keep tension on the thread spool and nudge the thread going onto the bobbin to ensure a neat even fill at consistent tension.
Clean out the rotary hook area and give it an oil. Clean between the tension discs on the top tension dial by turning down to zero to open up and running the edge of a piece of clean fabric waste between the discs.
Now check your bobbin tension, is it a front loading bobbin and bobbin case like the Brothers? If so, do the dangle test where you hang the bobbin by the loose end and see if it dangles, ie enough tension to hold the bobbin's weight, but will also release thread if you give it a gentle pull. If not, gently turn the tension screw on the bobbin case down a bit and try again.
Set top tension to the middle number on your machine. Now thread again paying attention to ensure the thread path is clear, raise the thread aerial if there is one, the thread is under tension in the bobbin correctly, and the top thread is also under tension when the pressure foot is lowered.
Set stitch length to 2.5. Now test sew, holding the two thread tails back out of the way as you start. Look at the stitch formation and adjust the tensions if it still looks too tight.
You can get lots of general info on www.sewing.about.com too which is helpfull.
I DON'T KNOW HOW TOTHREAD MY SEWING MACHINE INSTRUCTIOINS ARE NOT CLEAR ENOUGH I NEED HELP TO GET THE THREAD THROUGH THE MACHINE.
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Can't get Bobbin to wind properly
Verify that your thread path is correct when winding the bobbin. It has a distinctive path including a tensioner that helps your thread wind smoothly. Do not use a bobbin that is not wound smoothly because (as you already know) it could possibly break needles and damage the machine.
Brother CS 80 Sewing Machine Bobbin Rewind
Top Sew D'Lite Sewing Machines Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Sew D'Lite Sewing Machine Expert? Answer questions, earn points and help others
