I've checked and the current is coming out of the battery to the drill, but the trigger won't start the motor.
Hi- I'm sorry to hear that your switch has failed in your drill. Switches are covered under warranty as long as you are within the warranty period. You can locate your nearest Factory Service Center at the link below so we can assist you with ordering the part or handling warranty repair. Please be sure to the Factory Service Center.
http://www.blackanddecker.com/Service-Centers.aspx
If you have any questions, please let me know and I'll be happy to assist.
Thanks
Black + Decker Customer Service
A typical problem. The switch must be replaced with a new one.
The switch is not under warranty in any brand.
BUT in Greece the BD replaces it in case the drill is not very used.
SOURCE: black and decker cordless drill trigger
Ok, first check to see if the trigger lockout has been engaged, it's a small level at the top of the trigger ( I know this sounds silly, but it happens sometimes). Flip it side to side to see if you can hear the selector moving the switch inside the drill. If the selector moves freely without engaging the switch, you'll have to disassembly the drill housing to put the selector back into the lever so it will work.
Just take out all the screws in the housing and carefully remove the one side and look at the switch lever and make sure it is inside the slide selector lever.
If that isn't the issue, I'm afraid that the electric trigger/switch has failed and this isn't a part that can be disassembled and repaired by a DIY'er. I've attempted it when mine failed and found out it's a sealed unit and wrapped in a copper heat shield that dissapates heat when the variable speed is utilized and you end up destroying the switch housing in the process.
However, any DeWalt authorized repair center can do the repair for around $20 +/-, and if your drill is under the 3 year warranty period, it should be a free, warranty repair. Just contact DeWalt's customer service or your local Authorized Service Center (listed in phone book usually), or check the link for finding one near you.
www.dewalt.com or call 1-800-4-DEWALT (1-800-433-9258
Click on the "Services/Support" tab to get info. You can also buy the replacement parts if your drill is out of warranty (call them to verify before takin it apart!) and do the repair yourself.
Hope you find this Very Helpful and best regards!
