wikiHowhttps://www.wikihow.com > ... > Jewelry > Watches
10 steps
1.
Read the labels on the 4 buttons on your watch. If you can't look up a manual right now, you can probably figure out how to change the time with some simple ...
2.
Press the "Mode" button or hold it down until the time flashes. The minutes or hours of most digital watches blink when you're in the time setting mode. On ...
3.
Use the "Start/Stop" button to change the individual numbers. Once you get the minutes or ho
Diplodocs - CASIO: 1506 references - Your user manual immediately available! Your CASIO has four push button and one for winding button. the first button has mark of LIGHT , the below button is MODE ,,upper right START/STOP,,, lower is LAP/RESET. the center button is what they called it a CROWN to set crown is just pull it and you can set the hour and minute. the LIGHT button is the set button also, just press it for 15 seconds if dial flashes, then go to MODE button and choose what going to set, the START/STOP -- LAP/RESET is the scroll button you going up and down the number or on /off ,some model of Casio Edifice, the set is in the MODE button just press it long and if flashes it ok. and follow procedure what i said before. setting cannot damage the watch. Feel free to ask question regarding your to watch so i can assist..
Hope this may help;
1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
2 Pull the knob out from the watch slowly until it clicks into the first position.
3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
How to Set Digital Indigo Watches
1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
1) Press "SET/LIGHT" (top-left) button for 4 seconds.
2) Press "MODE" (bottom-left) button to reach blinking hour/minutes (~4 times press)
3) Change whatever you want (Hour/ minutes/ seconds/ date)
4) Press "SET/LIGHT" (top-left) again to set whatever you changed.
ENJOY
1) Press "Mode" button until Time is displayed. 2) Press and hold "Lap/RST" button until seconds display starts flashing. 3) Press "ST./STOP" button to change selected entry. 4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format 5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts
flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM 5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
1) Press "Mode" button until ALM is displayed 2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display) 3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press any button on the watch.
2)
3)
4) Press "Mode"
format>date format
time.
To set Alarm time:
is displayed.
flashing.
set the alarm.
1) Press
turn off alarm once the alarm sounds, simply press "ST./STOP" button on
the
watch.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
To set the digital time and date on your Timex, please follow the steps below.
Time and Location If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country. Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm Hold in the light, start and the reset button for a few seconds a screen will appear press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
