Cars & Trucks Logo
Posted on Feb 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How does one the change the lowbeam headlight bulb, 1997 bmw 740il
Need to change an H1 halogen headlight bulb.
drvalentine
Level 3:
Master:
  • Master 876 Answers
  • Posted on Feb 05, 2015
drvalentine
Master
Level 3:
Master:
Answers
876
Questions
0
Helped
255325
Points
4299
How do I change the lowbeam headlight in a Ford Escort?
the headlight bulb is both high /low beams and has a twist off black retainer that keeps the bulb in (DO NOT TOUCH THIS BULB WITH YOUR FINGERS THE OIL FROM YOUR SKIN WILL FRY ON THE GLASS AND BLOW OUT THE BULB IN AN HOUR OR LESS IF IT DOES HAPPEN CLEAN WITH ALCOHOL AND LET DRY) USE PAPER TOWELS/RUBBER GLOVE OR ANYTHING CLEAN TO HANDLE THE NEW BULB REVERSE REMOVAL PROCEDURE
1992 pontiac grand am headlight problems
Check that you have got the correct bulb for the one you replace . They both look the same but one has a single filiment for high beam only while the other will have 2 filiments for both high and low beam. If you are usin quartz halogen will be H1 the other will be H4
1helpful
How to change a light on a 2001 chev cavalier
remove upper air intake splash shield.remove the headlight housing retaining bolts and pull the housing assembly out to access the bulbs.rotate bulb holder counterclockwise to remove bulbs.WARNING YOU NEED TO WEAR CLEAN GLOVE TO REPLACE HEADLIGHT BULBS BECAUSE THEY ARE HALOGEN BULBS. IF YOU TOUCH HALOGEN BULBS WITH BARE HANDS. OILS FROM SKIN WILL CAUSE HALOGEN BULBS TO OVERHEAT BLOW OUT SO WEAR CLEAN DRY GLOVES.
NEED to change daytime running lights
YOU NEED TO RAISE THE HOOD,YOU HAVE TO REMOVE HEADLIGHT HOUSING BY TWISTING THE HEADLIGHT HOUSING MOUNTING RODS OUT OF THEIR CLIPS AND PULL UP THEM STRAIGHT UP TO DISENGAGE THE HOUSING FROM VECHICLE. WITH HEADLIGHT HOUSING OUT VECHICLE REMOVE LIGHT BULBS, YOU NEED TO WEAR CLEAR PAIR OF LATEX GLOVES WHEN HANDLING NEW HEADLIGHT BULBS BECAUSE HEADLIGHT BULBS ARE HALOGEN BULBS OILS FROM FINGERS OR HANDS CAN CAUSE HALOGEN BULBS OVERHEAT AND BLOW OUT.HALOGEN BULBS VERY EXPENSIVE THEY COST FROM $10.00 UP TO $20.00 OR MORE SO WHERE CLEAN GLOVES WHEN HANDLING BULBS.
How do have you change an headlight bulb?
LOOK IN YOUR GLOVE COMPARTMENT FOR THE OWNERS MANUAL. LOOK IN THE BACK INDEX OF MANUAL LOOK UP BULB REPLACEMENT. IT WILL SHOW AND TELL YOU HOW TO REPLACE HEAD LIGHT BULBS. YOU NEED TO WEAR CLEAN LATEX GLOVES WHEN CHANGING HALOGEN BULBS BECAUSE OILS FROM FINGERS AND HANDS WILL CAUSE THE HALOGEN HEADLIGHT BULBS TO OVER HEAT AND BLOW OUT. HALOGEN BULBS ARE EXPENSIVE THEY COST FROM $10.00 - $20.00 BE SURE TO WEAR CLEAN GLOVES WHEN HANDLING THEM.
1helpful
Need to change bulbs in headlights on a 2004 kia amanti
LOOK IN GLOVE COMPARTMENT FOR OWNERS MANUAL.LOOK IN THE BACK INDEX OF MANUAL LOOK FOR BULB REPLACE IT WILL SHOW YOU HOW TO REPLACE HEADLIGHTS BULBS BULBS ARE HALOGEN YOU NEED TO USE CLEAN LATEX GLOVES WHEN HANDLING AND REPLACING BULBS BECAUSE OIL FROM YOUR FINGERS OR HANDS WILL CAUSE HALOGEN BULB TO OVER HEAT AND BLOW AND HALOGENS BULBS VERY EXPENSIVE. THEY CAN RUN PRICE RANGE FROM $10.00 - $20.00 DOLLARS.
1helpful
Installing GE Halogen H1-55. (Car Hedalight)
There is no up or down side to the bulb
2answers
I would like to switch out my headlights for halogens
go to autozone they will do it for you. bobg22
How to change front headlight lowbeam.
Pretty straight forward. Open hood. Pull up on plastic cover over the headlight your going to fix. Low beam is the outside bulb. Rotate bulb counter clockwise ~1/4 turn and pull out. Reverse procedure to replace. Nuttin' to it!! Make sure that the old bulb comes out with an o-ring at the base. I usually have to remove it manualy. The new bulbs have new o-rings attatched.
5helpful
Changing headlamps on 2003 bmw 325xi
I am assuming that you have a burned out head light bulb.
1) Open hood.
2) Working in back of headlight assembly, grasp rear of bulb socket (harness connector) and turn counterclockwise 90 degrees. Pull bulb out of headlight assembly.
3) Disconnect harness connector from bulb (gently pry, it's plastic)
4) Installation is reverse of removal. (Do not touch halogen bulb with bare skin-oils from hand will cause bulb to burn out.) Align tabs on bulb base to cutouts on rear of lens assembly. (Note bottom tab is wider than other two) Secure bulb by rotating clockwise 90 degrees.
Low beam bulb H9006
High beam bulb H9005
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
