Tablets & eReaders Logo
William Spearman Posted on Jan 28, 2015
I would like to know is the (trio:) quad core tablet 7.85 8GB 4.4 blue tooth compatiable?
Nothing tried to parie with jawbone big jambox
Charaf Cherfi
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 28, 2015
Charaf Cherfi
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
83
Points
Yes its compatiable
Testimonial: "Thank you, I just have to see how to make it work. thanks again."
My tablet wifi will not turn on i already try to hard reset it
has it got an aeroplane mode in the settings that might be on ?
or a manual switch that might put it in aeroplane mode.
My tablet won't save to its SD card
Try another sd card to see if the problem lies with your original card or the tablet itself.
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Ho do i take music and pictures off my trio axs 3G tablet because my screen is broke in the top half
connect it to your computer with usb cable and copy files to your computer it should ask you when connect it what you wanna do or you can use my computer or start menu to browse the tablet and select files to copy to the harddrive
My Trio tablet I lock it and don't know how to unlock it
YOU PUT YOUR PASSWORD IN OR YOU FORGOT IT ?OU MAY HAVE TO TOTALLY RESET ..USAUALLY PUSH VOLUME CONTROL AND ON BUTTON AT SAME TIME TO GET TO RESET MENU
My trio stealth is new. When I power it on, goes to a screen "@9dual core" and doesn't go any further. Help!
There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also work, I've learned, on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned. But.... TRY AT YOUR OWN RISK. Here it is.
(1) PRESS AND HOLD the power button until the tablet shuts off completely.
(NOTE:
if any type of start-up screen comes on, FORGET it: the Tablet must be COMPLETELY powered off for this to have any chance of working.)
(2) PRESS AND HOLD the volume-down button, while simultaneously PRESSING AND HOLDING the power button
This will (hopefully) bring up the Android figurine, along with some kind of rotating-wheel graphic.
(3) Do nothing else but WAIT, until the screen changes to a text-based menu, with about 6 to 8, or more choices.
(4) Use the volume-up and volume-down buttons to navigate between choices, and select (highlight) the choice offering to reset the tablet (to Factory Settings).
(5) Click and release the power button to start the reset operation. Follow and additional prompts to ensure you are selecting the correct next step.
This RESET process will erase ALL your installed apps, as well as delete all your saved photos, music and other user files and preferences (including wallpaper, time-zones, Wi-Fi settings etc. But when it works it will give you back a working Trio. Use your reset Triot carefully: generally, I'll say the Trio machines are good economical alternatives to the perhaps more robustly engineered (and much more expensive) big brand items.
Regarding restoring personal preferences, and earlier installed apps I have no experience whatsoever. However there may be sufficient arguments to backup your personal data either on your home computer or on online "cloud based" services. Do the research, ok?
Happy New Year, 2015 ... & ....Good Luck!
2answers
Activate bluetooth on stealth g2
Hi Ali.. as far as i know and im pretty sure of this.. trio stealth aka Mach etc.. only has wi fi..no blue tooth. Here is a link with more info
for u.
http://youtu.be/mK-AGDPtoNU
Good luck
Chad man
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
