After downloading music to my sandisk i select the artist i have downloaded and from track 1 to the end of the album it is over in a matter of seconds! what's going on?
Resetting the player and taking the external memory card out and then putting it back in. i've tried a number of things but nothing works.this is only happening with any new music i'm putting on the player
When you say every time you download some files and if it says UNKNOWN. Then i would say the ID3 TAGS could be an issue. This issue occurs when information in a track's
ID3 tag is missing or incorrect. ID3 tags allows information such as the title, artist, album, track number,
or other information about the file to be stored in the file itself.
In order to fix this up. Kindly follow any of these steps..
Step 1:
1. Open Windows Media Player. 2. Under Library, look for the file to be edited. 3. Right-click the file, then select Advanced Tag Editor. 4. Enter the proper data for the fields available (i.e., Title of the track, Artist Name, Album Name, Genre, Track number, etc.) 5. Click Apply then OK.
Step 2:
Using Windows Explorer 1. Look for the location of the file. 2. Right-click on the file, then select Properties. 3. Click the Summary tab. 4. Click the Advanced >> button. 5. Look for the information you want to edit under Property. 6. Click the space under Value to edit the information. 7. Click Apply then OK.
1) You need to set the "tags" in the music files ... artist, album and song name. I would suggest opening up the files in MediaMonkey, which will let you edit the tags.
2) After you download the podcasts with MediaMonkey, you need to find out where they exist on your disk. Then, copy them to your Clip using Windows Explorer.
open windows media player and goto libary click on album artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... then syc with your sansa then load songs to it........
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
You can put music on it by doing the following (assuming vista/XP environment):
Connect it to your PC using the provided USB cable. Open windows explorer and navigate to your Sansa Clip. Click through "sansa clip", "internal memory" to the "music" directory. Drag and drop MP3/wav files to this directory. Feel free to create subdirectories. Your music will be accessible after doing this. Be aware that the clip ignores your directories. It will look for artist, album, and title tags to categorize your tracks. You may have to look for your tracks in the "unknown" album directory when playing if your tracks don't have these (ID3?) tags.
Before you select to rip the songs, edit them by renaming them - song - artist - album etc... then rip the music. Right click and select edit, then rename, press the tab key to go to the next selection artist etc.. and rename. You can also rip the music then go online to let media player find the details, but they do not always find the right details for the correct albums, so I always rename my albums myself
Select Recently Added, Artists, Albums, Songs, Genres, My Top Rated, Playlists, Podcasts, Audiobooks, or Recordings (Voice). - to view songs by album, artist, etc.
Or remove the track lisitng from the ID3 tag completely.
If you use a fileshare program to download music, sometimes some of the song information is changed and/or deleted. The album information is probably still with the song, but the artist info isn't. It's really stupid but the only thing you can do is just find the song through albums instead of artist.
your doing nothing rong if your divce can,t find a artis or cover this is the next thing it will do but if you use itunes set to manule load you can right what you like in
