check the heat switch in the rear. if it's on, check the thermal fuse in the top right rear of the brewer. it'll be in a now browned tubing. you can get it through bunn (800) 352-BUNN (2866)
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
I would remove the front panel and check the pressure stat to make sure it is set high, turn knob all the way to the right the back it up 1/4 of a turn. It that is done and after 7 minutes water is not hotter then the problem is on the top, the hi-limit needs to be replaced.
Syphon it out from the brew inlet hole in the tank basin, or remove the top panel and the tank basin, then remove the grommet on the pressure stat and turn it over in the sink.
