When I open my Sansa e260 mp3 player to add mp3's there is no music folder. i
SOURCE: sansa e260 4 gb mp3 player
You could reinstall the firmware (what makes the sansa work). Its pretty easy to do, no need of downloading/installig, its already all in the sansa. You just need a computer How do I restore the firmware Firstly, place the e260 in restore mode. To do this, follow these steps 1. Push the Hold button on top of the e260 to the right. 2. Hold in the record button 3. Press and release the Menu button 4. The device will now go into Restore Mode. If you have not already connected the USB cable to your PC, it will direct you to do so. 5. The root directory of the device will open up on the PC screen. Now drag and drop the two files Firmware into into the e260 root directory. You will find a copy of the two firmware files zipped up elsewhere on these forums 6. Push the Hold button on the e260 back to the left 7. Unplug the USB cable from the PC. The e260 will now reboot, writing the new firmware images to the correct location. 8. This process will have wiped all your music files. You will now need to re-synch.
SOURCE: deleting music from sandisk sansa E260 4FB mp3 player
you can change the usb mode in the sansa player settings to MCS then connect it to the computer, in windos xp the device will be recognized automacally. go to the explorer or to my pc and you should see it there.. go to the folder music and delete what you want,, you can copy music as well.
then desconect it safely and restart the device,, It will refresh the database and that's it.
you can change the USB mode bac to MTP if you wish.
SOURCE: Sansa e260 How to delete songs ?
This MIGHT fix the problem: Make sure that Windows Explorer is set to show hidden files and folders. In Windows XP, click TOOLS, FOLDER OPTIONS, VIEW and make sure you have selected "Show hidden files and folders".
SOURCE: i am wanting to delete music
Go to my computer scroll to sansa and open the music folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
SOURCE: I can't add new music folders to my sansa e260 because some go to
open windows media player and goto libary click on album artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... then syc with your sansa then load songs to it........
