55" UHD LCD LED TV. Need to reset so we can program TV correctly.
Http://www.lg.com/us/search/srch_manuals-tab?customerModelCode=55UB8500&mobileFlag=N#
Restoring the Default Settings
">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
SOURCE: lg lcd tv remote code
HI,
BUY A NEW REMOTE FROM E-BAY OR PARTSTORE.COM,TRY A UNIVERSAL ONE IF STILL DOESN'T WORK TV INTERNAL IR INTERNAL RECEIVER IS FAULTY,THANKS.
SOURCE: i need a manuel for my lg lcd tv.
http://www.lge.com/support/manual.jsp
Above is the link which should take you to the lG manual request. It is downloadable. The page is haveing difficulties right now, however it is the place top go
SOURCE: we have a lg 47inch
On your sky remote select interactive button, go too customer services and select option 5 , setting up sky remote, you should be able to find lg codes to try there. If not then try the internet for codes. You may have to wait though I didnt get my code for 6 months after getting new tv, but dont give up.
pete
SOURCE: I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best,
John
SOURCE: We just got a 55 inch LG LED TV. How do we set it
Easiset way is to use the HDMI Connecters and ports from the Direct TV box to the HDMI port on the TV...then set the imput source to the HDMI port that you used on the back of the TV.
Thank you very much what is the password?
Only if a password has been added, otherwise it would be all blanks, or zeros.
