If you suspect the battery try some spare batteries double checking with several known good to brand new one tests to cover your bases for consistency. It is a method of trial and error eliminating any possibility of a battery problem.
Sometimes there are power drain issues where cheep batteries even new can't handle. Trial and error illumination of a power drain issue checking with high power drain capable batteries. Information can sometimes be found in the manual in the specification.
From there you have the insight information it is not the battery in your further investigations describing the problem to a dealer or manufacture.
Other options of investigation include if you have the owners manual to check if there is any special settings to instigate you may need to know about dealers and the manufacture should know as well.
SOURCE: Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
SOURCE: second hand moves every 4 seconds
the battery need replacing this is what its supposed to do when batt low. if this helps please rate joe
SOURCE: Tag Timer Resets to Wrong Time
Unscrew the crown and press the lower button, this should advance the minute counting hand one press ata time. Pull ot the crown a further stop to advance the seconds hand and again to advance the tenths counter.
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
