How to adjust oven temp up on internal clock functions
SOURCE: temp/clock display faded
its the display that is going out on the ovenlike everything else things just fad away. Actually I have had LED meter displays do the same thing.
SOURCE: Smeg F170P-5 Oven
Models with analogue/digital programmer feature a "DEMO" function which deactivates the heating elements while leaving the other functions unchanged. To activate it, simply press the bell (minute minder), - and + keys for 3/4 seconds. A confirmation beep will inform the user that the function is active. To deactivate it, simply repeat the same procedure. This worked for my Smeg SC399X-6.
Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
