If your shower faucet was recently installed and you are getting this fluctuation in temperature there is a good chance your hot and cold water lines are crossed. Meaning the cold line is installed where the hit is supposed to go and vice versa.
You haven't provided much information to help narrow down the source of the problem.
Is the flow of both hot and cold water flowing freely? Are the water lines not clogged internally with corrosion or residue? Is it possible that the water is being diverted such as in an apartment building or to an outside spigot (sprinkler system) or kitchen faucets (dishwasher)?
Is your water heater temperature setting correct and is it supplying sufficient hot water flow to the shower?
Do you have a temperature balance cartridge in your shower faucet? If yes, it could possibly be faulty.
SOURCE: Triton Silhouette LED temperature fluctuations
Yes this one for the pro's call the company this is not something a most repair plumbers like to do...we would call the company they should know whats going on. If I was on the job thats what I would have to do, and then I would have them ship the parts to me. How old is it?
SOURCE: Fluctuating water temperature in new Price-Pfister Treviso shower
hi there! there is a technical problem in concern with that for sure...try checking the handle it might be loose already. things like that do happened all the time. thanks, kindly rate.
SOURCE: fluctuating temperature
Test: take the shower head off, then run water. If the water can be adjusted to the desired level (hot/cold mix), then the problem is probably in the shower head. Contact the manufacturer of the shower head. If you cannot maintain a good mix, the problem may be in the valve behind the wall or a total house pressure problem---time to get out your wallet and call a plumber.
