Powershot sx130
If your mode control dial is hard to rotate, there is chance that a sticky liquid may have sprayed or spilled, Take a q-tip with some rubbing alcohol or glass cleaner and rub around the outer edge, letting small amounts to slide under the dial. Begin turning the knob right away to work it in and loosen the stick. Make sure very little gets transferred from the q-tip, you don't want to short our the camera. It would be wise to do this with out the batteries loaded
SOURCE: Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
SOURCE: canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
SOURCE: Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
SOURCE: Canon Powershot s3 will not turn on or review photos.
It is likely that an internal integrated circuit in the DC/DC board is damaged.
You will need to have your camera reviewed by a qualified technician to have it repaired, since it requires open the camera and evaluate the DC/DC board performance.
Best regards,
SOURCE: how do i reset my
the menu's last tab has a last but one option where you can take all your settings to default. use it to reset your camera.
