Hi I have a back pack leaf blower that will only run between half to fully closed choke. When I open choke all the way it immediately dies. I took apart carb and cleaned it. Also replaced fuel lines in gas tank and cleaned clunker. Help needed. Also can you suggest settings for low / high speed adjustment? Thank you, John
Either your carb is still dirty as in has clogged jets or passages, bad diaphragm in the carb or you have the air/fuel needles way out of adjustment. Google what type of motor you have and how to set carb. Or even get a manual, that would be my advice. Also make sure you don't have to much 2 stoke oil in your fuel mix.
