Hosted an event last night and found one of my k5s pitch going crazy... works for a min then as soon as i drop be,low -2 its really slows was waydown..... Would it be the motor or picth conrol. we were throing a beach part on the beach around a lot of sand... Could that have an effect;l any help drop me an emil [email protected]
The problem could be 1 of 2 things - or a combination of them all...
1) Technics Pitch Control - if your pitch control is dirty, full of sand, this is more than likely the culprit and will need to be replaced.
2) Pitch Control IC's - there are 3 which are on the main circuit board, underneath the turntable platter. Any one or combination might have shorted out, a common problem.
In either case, you'll have to contact a qualified service center for repair, as neither are easy replacements. Good Soldering/De-Soldering skills are required to perform this properly.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Gear Repairs
It sounds like the problem is the pitch control. this is a common problem that can be fixed pretty cheap check out 1200s website they offer alot of help and replacement parts for this issue.
