20 Most Recent Technics SL-1210MK5 Turntable Questions & Answers
Will a counterweight off of a Technic 1200
Hi, yes it will. Cheers john. Stylus City
12/4/2013 9:01:22 AM • Technics... • Answered on Dec 04, 2013
My technics 1210mk5 have no power. I have never had an issue with them before.
Yes you can buy a wireless weather envoy MAPonline. Here are a couple of links to places that sell them http://www.bluewaterboundmarine.com/davis-wireless-weather-envoy-p-2321.html
7/17/2012 7:50:16 AM • Technics... • Answered on Jul 17, 2012
Technics 1210 poor sound
it must go in to a mixer,if you have then the channel select on the mixer is wrong.
7/10/2012 1:48:20 AM • Technics... • Answered on Jul 10, 2012
I'm using the serato dj software program.I had my
You check it by trying a regular vinyl record to see if it is the cartridge. Make sure you have the input on phono for vinyl and on aux if you are using serrato. If the turntables are older try cleaning the contacts on the tone arm where the cartridge goes. make sure it is grounded properly also. Try plugging the turntable that is not working in where the working one is to check the channel on the mixer.
3/24/2011 12:42:24 PM • Technics... • Answered on Mar 24, 2011
Hi i bought my technics 1210mk5's in america and
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
6/10/2010 4:11:34 PM • Technics... • Answered on Jun 10, 2010
1210 mk5 poor sound
If the cartridge is good and your wiring is good. Then it's either got to be a fault on your amp, or there is a pre-amp in the deck itself faulty. Double check that the amp is working, amps have a pre-amp for record decks, they cause trouble a lot.
If you touch the wires that connect to the cartridge, you should get a buzz on either channel (remove them from the cartridge first). If you don't get a decent buzz, and you know that the amp is working fine, then there's something inside the deck causing the problem. In which case take the bottom off and take a look inside.
2/12/2010 9:00:19 PM • Technics... • Answered on Feb 12, 2010
2answers
Buzzing from one Technics MK5 1200
More than likely your RCA's need to be replaced. There is no need to open it up, as the ground wire rarely every comes loose. It's held down by a screw & soldered to the circuit board. Unless you pulled on the ground wire.
There are only 3 issues which can cause this:
1) Technics Tonearm - Check the 4 prongs inside the tonearm. Make sure they are all clean (shiny gold), and all protruding the same distance. There are springs behind these prongs, and often times they do come loose over time or overtightening.
2) Technics RCA Cables - This is more than likely the culprit.
3) Cartridge/Headshell - swap out with your good unit. If it works, then your good. Just replace cartridge
With the exception of #3, the other 2 will require assistance from a qualified service technician, otherwise you could cause more damage to your turntables.
- OPTiC
Master Tech, 1200s.com
Technics Parts : Technics Repairs
1/27/2010 4:21:00 AM • Technics... • Answered on Jan 27, 2010
2answers
Pitch control drops drastic in middle of set
it sounds like the problem is the pitch control. this is a common problem that can be fixed pretty cheap check out 1200s website they offer alot of help and replacement parts for this issue.
8/29/2009 4:37:36 PM • Technics... • Answered on Aug 29, 2009
2answers
Skipping
That is correct, your tonearm needs to be replaced.
By adjusting that top screw on the tonearm, you only made the problem worse. It's very hard to realign that screw, as those are machine calibrated, and once tampered with, almost impossible to get back to exact factory settings. We recommend replacement of the entire Technics tonearm.
- OPTiC
Technics Parts : DJ Gear Repairs
8/29/2009 4:32:02 PM • Technics... • Answered on Aug 29, 2009
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Dan
7/20/2009 1:16:52 AM • Technics... • Answered on Jul 20, 2009
3answers
Frequent sound
Please re-check all your other equipment, as its highly unlikely to be the 2 turntables at fault, let me know how you got on.
Regards.
http://www.audiovisualservices.info/
6/13/2009 1:25:06 PM • Technics... • Answered on Jun 13, 2009
Needle for Technics mk5
Ok, the needle is just a small portion of everything required to get up and running. Here is a diagram of what your going to need:
The stylus, also known as the Needle, is what you are asking for. As you can see it's only 1 of 3 items you need:
1) Headshell
2) Cartridge
3) Stylus / Needle
If you already have 1 and 2, and you need to replace #3, then we would need to know what model #2 is?
You'll need what's called a STANDARD Mount cartridge, (aka Half-inch). In addition, that cartridge will need to be mounted to a Standard Mount Headshell.
Here is a collection of Standard Mount Cartridges that will fit this model.
Try to stay away from those all-in-one configurations that look like the Concorde airplane. Over time they will damage your tonearm due to a poor design flaw. Stick with a set up similar to the image posted. You can't go wrong, and you'll have more options.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
4/30/2009 5:10:46 AM • Technics... • Answered on Apr 30, 2009
I didn't touch the pitch adj control, i didn't
This is an issue with the main drive circuits. You have what we call the 'washing machine' affect.
Only a qualified technican can repair this for you. Not too costly, if the tech knows what to look for. If not, then he will spend many wasted hours trying to find the damaged circuits. Make sure you explain the issue to them and ask if they've fixed it before.
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
4/30/2009 5:05:31 AM • Technics... • Answered on Apr 30, 2009
2answers
A friend just gave me a slightly used Technics
You'll need what's called a STANDARD Mount cartridge. In addition, that cartridge will need to be mounted to a Standard Mount Headshell.
And here is how it all comes together...
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
4/30/2009 5:03:48 AM • Technics... • Answered on Apr 30, 2009
Tone arm replacement
Any TV repair shop will be able to perform that repair for you as well as get any parts necessary. Steve Medley
2/8/2009 6:07:56 AM • Technics... • Answered on Feb 08, 2009
2answers
Help: Mk 5 Tone Arm
Tonearms if not installed correctly can screw you your records over time. Personally, I'd pay the extra 20. Good Luck.
12/30/2008 11:41:48 AM • Technics... • Answered on Dec 30, 2008
2answers
Tone arm skipping/not moving on especially at end of record
The issue is with your tonearm, and not your tracking. You probably have slight damage to the tonearm bearings, which will cause this. There are 2 options... you can try to adjust the pivoting screw at the top of the tonearm ... However, WE DO NOT RECOMMEND THIS, because once you mess with this screw, it's EXTREMELY difficult to get it back to the correct setting, as this screw is machine calibrated at the factory. So, we only recommend this when you have no other choice, or it's an emergency (the middle of a set).
You can view a video on how to do this, by going here - http://djprolab.com
Eventually, your going to have to have your Technics Tonearm replaced. This should be done by a professional, as it is not an easy replacement.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
12/30/2008 11:35:17 AM • Technics... • Answered on Dec 30, 2008
Slow start
There is something wrong with your drive system. Unfortunately, you will have to have a service professional take a look at this.
More than likely one of the Integrated Circuits (IC's) have gone bad and will need to be replaced - a common issue on the newer models.
- OPTiC
The 1200s Expert
www.1200s.com
9/8/2008 2:03:43 AM • Technics... • Answered on Sep 08, 2008
Speed regulator.
First and foremost, are you located in the U.S.? If so, make sure your unit's voltage is set to 115V rating. The switch is located under the turntable platter. All you need is a flat head screwdriver to turn it to the proper voltage. If it's on 220V, you need to change it. If you are not in the U.S., or it is already set @ the proper voltage rating, your problem could be one or many issues with the drive, and pitch control. There are various resistors, capacitors, IC's and variable resistors, which control the drive. Any one of these could have gone bad on you. Do you have a runaway operation, or is it doing that back and forth movement? In either case, this cannot be self repaired, and you will have to take it to a qualified service center for repair. Cost will run you anywhere from $60-120 - if they go higher than that, they either do not know what they are doing, or they are trying to pull one over on you. We work on these on a daily basis, and should cost you more than that. However, prices do depend on where you live (we are in NYC). Good luck!
9/23/2007 10:31:48 AM • Technics... • Answered on Sep 23, 2007
Technics SL-1210MK5 Turntable Logo
Popular Tags
23 questions posted
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Technics Audio Players & Recorders
Most Popular Question
technics 1210 poor sound
  • Audio Players & Recorders
