Faucet isn't leaking, handle is just loose.
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
SOURCE: Moen One-Handle Kitchen Faucet Leak - Hot Only
http://www.moen.com/browsecatalog/catalog/specpartsearch.cfm?location=TopNavCustomerSupport
Moen uses a cartridge on their faucets. You have to remove the handle. You will find the stem and a small U shaped retainer. Pull the retainer out and pull the cargridge straight up. Sometimes the cartridge is in there pretty tight and you have to pull hard. Once you do this, take the cartridge to your local hardware store. Replace it with the one you have because they have 2 different one. Install it back in the same order it was removed. Hope this helps and good luck.
SOURCE: I just installed a new cartridge in a moen single
try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
