Windows XP at this point is very buggy due to lack of support
Try to access your unit in safe mode and see if it works
when powering on press constantly F8 then select safe mode
if you are able to get in - try to save your information
if unable to get in and still getting a blue screen it could be either a system failure or hardware failure
Testimonial: "it wont boot up in safe mode, what could the hardware error be? it was on the night before and then it just suddently stopped and started blue screening at launch of the OS"
SOURCE: Dell latitude d610 dark screen
there is a inverter in LCd that makes your lcd bright white shine. when it breaks down you see black screen. something happens on lcd you cant see clearly you should go to service and need to be changed INVERTER.
pls rate
SOURCE: my dell laptop latitude d610 have no audio sound
Go to the DELL support page
http://support.euro.dell.com/support
Click drivers & download
enter your system type and model
You will then be presented with all the drivers for your D610.
Download the Sigmatel driver in the Audio section.
Save the file then run to install the driver.
SOURCE: DOWNLOAD OF DELL LATITUDE D610 SOUND DRIVERS
You can download the DELL D610 driver from the link below. You can also download all other drivers and utilities from this link.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=LAT_PNT_PM_D610
SOURCE: dell latitude D610. Screen goes black. External Monitor OK.
Make sure you have not accidentally used the FN+F5 key
That combination sets the laptop to use an external display.
If using that does not give you a display take a small torch (flashlight if in USA) and shine it at an angle on the laptop screen.
If you can see any sort of picture you would be looking at replacement of some minor parts to the laptop screen
Hope this gives you the information you need. If not add any extra information you may have and lets see if we can FixYa
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Backup all the data you want to keep on an external hard drive, flash drive, or rewritable CD. Resetting your Dell to factory defaults will erase all data currently on your computer.
Insert the Recovery CD into your CD-ROM.
Reboot your computer.
Watch the text in DOS carefully. When prompted to boot from your CD, do so.
Choose System Restore and then follow the instructions presented. Once system recovery beings, it may take a few minutes. Once it's done, your system will reboot again.
Remove the Recovery CD from your CD-ROM and store it carefully. Your system has been reset to the factory default.
