When I turn the TV on it says Air 31.4 Digital or 31.42 Digital then it shuts off quickly.
SOURCE: code for sky+ remote cotrol
If you mean you want to program the remote to control your sharp tv, here is the list of sharp codes:
0093, 121, 121, 064, 065, 081, 322, 122, 185
SOURCE: I can't get rid of the teletext subtitles
go into your cutomer menu and trun off close caption
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
SOURCE: Failed to receive broadcast E202 Sharp
What do you mean exactly when you say "failed to receive broadcast"? Does it not get a signal of any sort? What about from DVDs, do you have a DVD player attached, does that work? Did it used to work just fine with regular TV signal?
Thanks, let me know more and I can definitely help!
Tim
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
