SOURCE: admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
SOURCE: admiral washing maching model aav7000aww
Hello donerehart
You said, water and spin cycles are fine, but won't agitate... what can i do?
Sounds like the timer in the dial will not progress!
SOURCE: I have an Admiral washer
The washer has a floating motor mount. Sometimes the motor mount will stick in one position and the belt will slip during the spin. UNPLUG the machie. Get some blocks of wood and clock up the front legs 4 to 6 inches. Then reach under the bottom and just squeeze the belt together. Your trying to get the motor mount to slide in it's mount. (normal) After you let go of the blet the motor should retension the belt. Do this several times forcing the motor to float. You can if necessary shoot some WD 40 around the mount sliding area. DO NOT get it on the belt. Remove the belt if you have to and reinstall it after you lubricate the motor mount. Any oil will work if you do not have WD 40. Like I said DO NOT get any oils on the belt. After your done with lubrication squeeze the belt mid point again and let go. The belt MUST re-tension. It is not a horribly tight tension but tension that is noticed.
If after you do the belt tension check / motor mount slide lube and you still have the problem just respond here. There are more things that can be checked. I will gladly help you.
Thanks for choosing FixYa
Kelly
