Need manual
SOURCE: Measurements for Rice
Most of my experience with the rice cookers is that they require a japanese rice Cup which is different than the japanese regular cup. makes a whole lot of not sense but i found a replacement cup at one of the local Japanese Markets if you had to you could use regular measuring cup and use the 160ml for your measure. also the cup has a "Inomata" on it so maybe the web can help you
Eat lots of Rice
SOURCE: Rice Measurements
You use one cup of water for each cup of uncooked rice. You end up with about 2 cups of cooked rice for every cup of uncooked rice. Different varieties, such as brown rice, take more water, up to 2 cups of water per cup of uncooked rice. If the resulting rice is too dry, you can add more water and restart the cooker.
I am not sure, but I believe that 16 cups refers to cooked rice, so you should not put more than 8 cups of uncooked rice in the cooker.
SOURCE: how to use HS800 flavor scenter 4-cup rice cooker
http://www.useandcaremanuals.com/pdf/HS80035.pdf
is the manual for this product ---
SOURCE: black and decker flaver scenter rice cooker manuel
is the pdf of the manual for this product
