Sound Storm Laboratories SD714MB Car Video Player Logo
J
Jermaine cobbs Posted on Sep 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to show images on screen
Touch screen don't work
  • ZhiWa Dec 05, 2019
    Hello, I want to say that, I don't know too much about it but u can try this
    Amazon.fr
    distriphone(point)com
fasinew
Level 1:
  • Contributor 4 Answers
  • Posted on Oct 16, 2019
fasinew
Contributor
Level 1:
Answers
Questions
0
Helped
1812
Points
15
I essentially started about a month and a 1/2 agone and i have gotten a couple of test for a whole of $2,200...this is the bestcall I made amidst pretty some time! "grateful to you for giving Maine this incredible possibility to profit from home. This similarly cash has changed my existence in such an excellent measure of courses, to the point that, bypass on you!"....... www.amazon78.com
cronked83
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 87 Answers
  • Posted on Sep 29, 2014
cronked83
Expert
Level 2:
New Friend:
Cheetah:
Answers
87
Questions
Helped
14939
Points
203
Step 1 Turn the device off, wait a few seconds, and then turn it back on again. This process will clear out any software errors that are causing the touchscreen to malfunction. If the touchscreen still doesn't work, remove the device's battery, if possible, wait ten seconds and then put it back in.
Step 2 Remove both the SIM and memory cards from the device, if the device accepts such cards, and then turn the device off and back on again. Sometimes errors in these cards can cause devices to malfunction.
Step 3 Check your device's documentation to see if there is a way to manually recalibrate the screen. This process will either be done through the "Settings" or "Tools" menus, for those devices that have an alternative method of input, or by holding a combination of buttons while you turn the device on, for those devices that only have the touchscreen for input.
Step 4 Upgrade the device's software to the latest version, if possible. Many devices come with software for your computer that will allow you to connect the device and update the software. Often, this process will resolve existing software errors that may be causing the touchscreen to stop responding.
Step 5 Clean the device's contacts and screen using isopropyl alcohol and a small brush. Turn the device off before you clean it.
Step 6 Perform a hard reset as a last resort. This reset will erase everything you have added to the device and return its software and settings to their factory defaults. Even with an unresponsive touchscreen, most devices will have a way to perform this reset either through PC software or by holding a combination of buttons while turning the device on. Consult your device documentation to determine the exact process for performing a hard reset on your device.
Step 7 Contact the manufacturer for your device if the touchscreen is still unresponsive after your troubleshooting attempts. The manufacturer may have additional steps to take that are specific to your device, and if your device is still under warranty you should be able to get a replacement through their customer service division.
Warnings
  • If you have the right tools and are willing to risk voiding your warranty, you can also open the device and scrub down the control board using the small brush and isopropyl alcohol.
  • Many manufacturers offer free telephone support, but some will charge for the service. Check your product documentation before you contact support to know if you will be charged for the service.
Required Items
  • Isopropyl alcohol
  • Small brush
References
How to fix id card fuction
first entered in SPECIALFETURES then
IMAGE COMBINATION then (Machine Ask Original Paper Size)
Select A5R (if the LTR Size Show tuch the AB botton)
Select 2 on one then select A4 paper tray
Then Screen Show Special features
DO NOT TOUCH RESET or Any botton
touch MODE MEMORY select M1 touch STORE then done then OK
Press the Additional Function Bottoan
touch Copy Setting
touch Standred key 1 setting
(in this Window show many botton)
choose modememory Select M1 Select OK
afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
Touchscreen does not display
YOU DROPPED IT, THAT EITHER BROKE THE MONITOR OR THE CONECTION TO THE MONITOR BUT YOU SAY THAT WHEN YOU HOOK UP TO A MONITOR IT WORKS OK.YOU CAN FIX THE PROBLEM YOU GO TO E-BAY AND TYPE THE NAME AND MODLE NUMBER ONCE YOU ARE IN E-BAY LOOK FOR THE ASUS Q200E AND YOU ARE LOOKING TO BUY ONE FOR PARTS WITH A GOOD SCREEN...[REMINDER IT WOULD HELP IF YOU GET A PAY-PAL ACCOUNT.AND MAKE SURE YOU HAVE A MINI SET OF PHILIP SCREW DRIVER AND A MAGNET TO KEEP SCREW TOGETHER.
AND PAY CLOSE ATTENTION WHEN DOING THE REPAIR
PLUS YOU'LL HAVE EXTRA PARTS.
GOOD LUCK.
KM Bizhub c353 touch screen
replace
Btw, Iā€™m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
The screen don't show image
press the eye/lcd button just under eye piece.
I don't know how to use a touch screen. What do the icons mean?
jus little pics that show up on your screen or files u have on it
2answers
When I turn on my NDSL the touch screen is white
The bottom screen is made up of 2 parts the screen itself and the touch screen mambrane which sits on top of the screen, if the touch part is still woking then the screen is faulty and will need to be replaced.
There are some good videos on youtube that will run you through the process of changing just the screen.
1helpful
2answers
Touch Keys and Screen
I think this a problem related to the flex cable that connects the main phone body to the sliding screen. Over time the flex cable wears down as it slides and results in a whole range or problems such as: display acting weird (eg. mirror-image and inverted colours), speaker not working, off-button not working etc.
Flex cables are cheap to buy on ebay (a few dollars) and there's internet sites that show you how to open the phone and replace them. (google: samsung u700 replacement flex cable)
Touch screen shows images but doesn't respond to touch
It is most common problem with this handy cam. just get the patch cord replaced at ant sony centre. it is not that expensive.
Kumar
Top Sound Storm Laboratories Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Sound Storm Laboratories Car Audio and Video Expert? Answer questions, earn points and help others
