The solution to Fix Brother Printer Error 0b:-
To kill this Brother Printer blunder code 0b, experience the focuses underneath. Take a gander at the means beneath:
-Press and hold the control key as a matter of first importance to close the PC off
-Unplug the power line from the machine's back
-Sit tight for around 30 seconds. Wire once again into the PC the power rope. 4. -To turn the PC on, press and hold down the power key
-At that point, if the PC shows "Set," the issue is fathomed
Change your username
If you use Gmail with your Google Account, it's not currently possible to change your Gmail username after you've registered unless you want to delete Gmail from your account and use a different, non-Gmail address for your Google Account. You can also create another Google Account with a different Gmail username.
If you don't use Gmail with your Google Account, you can change your account username to another email address at any time. Your username is the full email address you used to create your account.
To change the email address on your account, just follow these steps:
Once you've saved the change, you should receive a verification message at the email address you just entered. To complete the change, you'll need to click the verification link in this message. You should also receive a message at your old email address confirming that we've registered the change to your account. If you don't receive the verification email, check your spam folders or request a new email.
Note:
