Coleman Powermate Premium Plus 6250W Portable Generator Logo
A
Anonymous Posted on Sep 12, 2014
Plug fouls out turns black and starts to backfire
Generator runs good at half choke but plug fouls out and it begins to backfire should I run with choke full open when it runs so it don't load the plug
CJ Rock
Level 3:
  • Coleman Master 4,429 Answers
  • Posted on Mar 11, 2019
CJ Rock
Coleman Master
Level 3:
Answers
4429
Questions
0
Helped
1645497
Points
15024
Half choke to run and plug fouls with thick black deposits in a few minutes of operation. Likely low compression and its burning oil. Piston rings are shot, possibly more.
How old or better yet how many running hours?
If thin sooty black plug fouling then clean and or replace carburetor.
gary010foryo
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 25 Answers
  • Posted on Sep 14, 2014
gary010foryo
Contributor
Level 1:
New Friend:
Night Owl:
Answers
25
Questions
Helped
8928
Points
31
Carbs2 rich or plug's 2 cold \nt gappd rt boohoo
john d
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Sep 13, 2014
john d
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
3340
Points
10
What does the oil look and smell like? Also what conditions is it been ran in lately, and what fuel are you running?
3 Related Answers
hawkchuck
  • 4 Answers
  • Posted on Jan 02, 2009
SOURCE: Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Anonymous
  • 4088 Answers
  • Posted on Jul 14, 2009
SOURCE: Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Anonymous
  • 3 Answers
  • Posted on Jan 17, 2011
SOURCE: i have a coleman powermate premium plus 6250
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
When my Honda, became cold nature more choke then usual and a dead miss then warmed up and was backfiring ?
did you foul the plugs , this is something that happens all the time when you have a hand choke on something , when it gets cold out you are going to need more choke, the best thing to do when it is cold is to warm it up do not just take off because you always leave the choke on and foul the plugs, warm it up leave it alone , do not fix something that is not broke
I have a clark g900/700w generator.i started up today.started ok but when i turned the choke off it started to cut out.it will only run on half choke thanks
Is the gas fresh?
Possibly stale gas is the problem
http://www.clarkeservice.co.uk/manuals/generators/g900.pdf
Has engine been serviced: clean air filter, fuel filter, spark plug.
Clean out fuel system with carburetor cleaner. Place about 12 oz. in fuel tank and run engine.
1helpful
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
I bought a 92 fzr 600 ride it for a month no problem. But now it keeps popping the resistor in the spark plugs. 3 sets of plugs in the last 2 weeks. Last set lasted 2 days. All have been ngk.
NGK plugs dont stop, especially all at once, so there is another problem.
There are some resisters in the plug caps that can fail.
Are the plugs carbon fouling?(dry black) if so make sure the air filter is new, and oil is changed.
Does the enginge blow smoke or use oil?(wet black)oil fouled may mean rings.
Fuel fouled may mean the jettting is wrong or choke stuck open
Its the battery good(new) and charging ,put a multi meter across the terminals 12v stopped, 14v running approx.
it always helps to drain the carb bowls every few weeks
If exhaust is not standard, the jetting may be wrong.
does the fuel tap work correctly? only use the run or res positions never pri
A short in the kill switch or a worn ignition switch can cause a miss or backfire
Half the hoses are missing lot of open vacuum leaks choke wont operate truck missing wont crank cold
There should be a vacuum hose diagram on the underside of the hood. Try plugging any leaking hoses to get it to run decent first, could have a fouled spark plug for the missing problem or a bad spark plug wire. As for why it won't crank cold, is the battery any good? Has to be charged up good to crank the engine over and fire the spark plugs. As for the choke not working, is it electric? If so, check for power at the choke thermostatic housing, the round black thing, should have a wire going to it that needs power to warm up the choke thermostatic spring.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2496c4f07ad24453
1helpful
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
Generator starts runs with a miss for a minute or 2 then dies just changed oil and plug checked gas supply was good any idea whats wrong
If you have good spark, clean air filter (replace anyways), try choking it half way or so. If it runs better, then it is running too lean, probably a clogged orifice or jet in the carb. If choking it makes it run worse, then it is likely running too rich. Could be a float problem, or metering tube that is clogged and isn't spraying.
1helpful
2answers
I have a gsxr 750 1990 the L modelk its in good condition and has been well cared for.when I bought it running grand but needs to have carbs balanced out as running a bit rich on 1 plug. it wont start, its...
Don't use cold start.it will not solve your problem.Try running it with out the air cleaners ,it may be that you have an air intake problem and not getting the right Air / fuel mixture .
6helpful
2answers
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
