use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
2wire lost password reset 2wire dsl modem sbc 2wire router modem unlock 2wire 2wire 1701 hg ...2wire homeportal 2wire 2700 2wire can't get ip address .... default 2wire password 2wire modem att white paper 2wire gateway ip address .... usb 2wire hpna linux working for 2wire wrt350n and 2wire modem ... groups.google.com/group/alt.languages.catalan/.../a1f780eac37721f2
The 2Wire HomePortal is a wired solution that offers subscribers hassle-free, ... Cisco-Linksys EtherFast Cable/DSL Router with 4-Port 10/100 Switch ... 5.0 out of 5 stars I could not ask for anything better than this., December 17, 2006 ... I waisted my money. My tech guy said it was an older generation unit, ... www.amazon.com › Video Games › Mac Games › Hardware
Contact the ISP (Internet Service Provider) who provided the 2WIRE router to you. They will tell you the "default" password, and will tell you how to "configure" your wireless network to be "secure".
At that time, you will set a password.
For most models, browse to the 2wire's GUI by typing gateway.2wire.net into the address bar. 1) Click on the homenetwork icon. 2) Click on wireless settings 3) Enter your system password 4) Left hand side under encryption change from WPA to WEP 5) Save.
The best solution is to reset the router. The easiest way to do this is to find the reset button, usually on the back of the router there is a pin hole button. Use a pin or pencil to push the button.
Be warned, any special settings will be lost, but most installations of home network routers such as the 2Wire Router/Gateway is the default settings. If you have other than the default settings, then contact the person/organization that set up the 2Wire for you, such as your ISP/Internet provider.
First have a computer directly plugged into the 2wire
Using windows xp: click on start> then run> then type "cmd" and hit enter.
Type "ipconfig" and hit enter.
You are looking for a default gateway address, usually "192.168.1.254" on 2wire gateways.
Skip the vista section if you are using xp
Using Windows Vista: click start> then click on the search bar and type "cmd" and hit enter.
Once you find the gateway address, you now have the website address you need to get to your 2wire. Open internet explorer and type that default gateway address in the address bar.
This should take you to a 2wire homepage. At the top click on the "home network" or "local network" tab at the top.
Once there, click on the wireless network link at the top. It will prompt for a password, if you do not know the password, click I forgot for a hint. Click I still cannot remember if the hint doesn't help, it will ask for a system key, which is a 10-digit number on the bottom of the 2wire.
After entering the password you will be in the wireless settings window where you can change the security type to any available that the 2wire has, if it doesn't have it available call the provider and see if they have a firmware upgrade available.
