20 Most Recent 2wire 2700HG-B Router (2700HGB) Questions & Answers
Hey Capb, sounds like this "modem" is set up differently from the old one in that it is separating the wired and wireless network traffic. If you are a little technical, you might check the IP addresses of both devices and see if they are on the same networks segment.. like 192.168.1.100 and 192.168.1.101 or some such.
2wire 2700HG-B... | Answered on Feb 16, 2019
You once have to check once that which operating system you are using and check the DHCP and firewall Settings too. You may also check Linksys router support here you get more about Routers. For more Information regarding Routers Visit:https://www.routertechnicalsupportnumbers.com/linksys-router-support/
2wire 2700HG-B... | Answered on Oct 04, 2018
Buy Zocon-T Kit (Fluconazole/Tinidazole) is used to treat the symptoms of various va*inal yeast infections including vag*nal trichomoniasis, va*inal candidiasis, and bacterial .
2wire 2700HG-B... | Answered on Aug 20, 2018
if its new then you must not have issue with it, if the configuration they gave is already setup and nothing missing, it should be ok.
If the electrical issue is true, then you try to use AVR or other power supply for your modem.
You can also try to plug it in different place and try to connect with it (even without internet) to test if its really the electrical thing causing you this headache.
"Rebooting the modem by itself is not normal" (possible hardware cause).
Otherwise, you should ask for its warranty or replacement.
2wire 2700HG-B... | Answered on Jan 05, 2018
No you must connect to the router port to get time capsule connected to network
2wire 2700HG-B... | Answered on Nov 04, 2017
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
2wire 2700HG-B... | Answered on Sep 27, 2017
Replace it since its operation is intermittent and sooner or later it will quit for good.
2wire 2700HG-B... | Answered on Sep 05, 2017
When I purchased the same router on Amazon I did my best to set it up on my own, but you need the correct IP information you can only get from your customer support at AT&T. I'm using this router with an old Airport card in an 2003 iBook and a 2007 iMac (built in Airport express card). The set-up was all done wirelessly, with bellsouth (AT&T) customer service instructing me over the phone, the process took about 15 minutes.
My suggestion is to call AT&T and speak with someone who knows what their doing, and they do use the SBC global page to set up the unit, starting with http://192.168.1.254/ for the system summary, from there you can set up your password etc...
2wire 2700HG-B... | Answered on Jun 13, 2017
Hi, It's your power cord. You need to purchase new one. take a look on amazon, here: Finally charging for our multi device world. I hope I have helped. Cheers
2wire 2700HG-B... | Answered on Dec 03, 2014
Wireless is supposed to blink. Check to see if the power outlet might be giving out. If not, then you might have to replace the router.
2wire 2700HG-B... | Answered on Nov 04, 2014
2wire 2700HG-B Router (2700HGB) Logo
618 questions posted
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • 2wire Computers & Internet
Most Popular Question
sbcglobal 2wire but want n wireless
  • Computers & Internet
