The TV just shuts off and the Standby/Temp and Lamp light flashes up to 29 times.
I recommend trying a new lamp, part# BP96-01472A
see the following website: http://www.shopjimmy.com/catalogsearch/result/?q=+BP96-01472A
SOURCE: 2004 Samsung DLP HLN-507W1X:Flashing lights
you either need another Lamp which is very possible or Ballast Board. Ballast board is what turns Lamp on, pull back watch to see if there is a Ark coming from spark cap on Ballast board if so Lamp if not Ballast board call Mats for lamp 1-800-628-1118 OR Go to E-Bay for Lamp and Ballast Board Look under TV Parts After rereading your Post I think Lamp! Samsung OEM Had Alot of defective Lamps and do not hold up!
SOURCE: The TV made a pop noise and the TV shut down. I
here is this could wrokhttp://www.ehow.com/how_5535314_reset-lamp-hours-tv.html
SOURCE: Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
SOURCE: Looking for technical help for Samsung 61" 1080p
Hope you got helpful info from our expert to
solve your tv issue, if you still need further help, let me know to
assist you further along with info what actions have been taken to fix
the problem.
Thanks.
SOURCE: Samsung HLS4266 DLP tv.
In all likelihood then the ballast is failing, this is very easy to
replace just a little board attached to the lamp by a couple of wires,
just when you remove lower bottom have a look at the lamp wires and you
wont go far wrong it's available here
http://www.partstore.com/Part/Samsung/Samsung/BP4700037A/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HLS4266WX
The part is in that link highlighted in my last post just click on it
and it will take you to the supplier, if you cant fit it yourself a
technician shouldnt charge more than $100 for the housecall and fitting
unfortunately there are a lot that want $150 just to turn up so if you
could get someone whos practical this is very easy to do.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
