See page 22 troubleshooting of this manual. It may help you.
dd501 (yamaha.com)
SOURCE: bought a new electronic drum
Double check and make sure all the chords are plugged into the control box for your set. Most electronic drum sets require the use of headphones or some sort of PA system to hear whats being played. If you could expand a bit on the description of your problem, I should be able to help more.
SOURCE: i want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
SOURCE: For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
SOURCE: The Bass Drum Pedal of our Yamaha DTXplorer
Go to one of the suppliers. Most of them will have photos of the bass pedal assembly and if you can enlarge the photo, you should be able to figure how to assemble it.
Expect to find washers on shafts between things that rub.
The owners manual at:
http://yamahadtxplorer.com/yamaha-dtxplorer-owners-manual/
Check on page 9 for example. While the photo isn't the greatest you can see where the spring is.
SOURCE: I require a complete set of fixing bolts for a
If you contact Yamaha keyboards and tell them the model of your keyboard they can tell you exactly what part numbers they are and tell you how to order them. Here is the link: yamaha24X7.com.
