20 Most Recent Alesis DM6 Electronic Drum Set Questions & Answers
2answers
When I hit the snare
I believe I have found a good part of the solution to this problem. I also had this problem in the snare. The problem was so severe that, when pulled, the snare support, without giving him any beat, the sound appeared. I took courage and opened the snare.Ao open, I realized that a yellow adhesive used to glue the trigger wire had melted and the other touching the trigger. I think this must have happened at some point prior to my purchase that equipment has been under excessive heat and then drained to such a glue. Simply cut the little wire glue "connected" two triggers, and closed the snare ....... ready: is working perfectly.
12/8/2014 5:28:34 PM • Alesis DM6... • Answered on Dec 08, 2014
How fix the firmware problems with alesis dm6?
Have you updated the firmware recently? If not, do so. If you are having volume issues, you can adjust them with the following: Adjusting the volume of individual pads: -Press Voice. -Then press Volume. -Strike the pad you would like to adjust. -Then use the + and - buttons to adjust the volume of the individual pad. -To adjust another pad, strike that pad, and repeat step 4 above.
8/5/2014 11:07:31 AM • Alesis DM6... • Answered on Aug 05, 2014
I own an alesis dm6 mod. how upgrated firmware?
Click this to unload the latest firmware from the manufacturer! DM6 Module - Firmware Update [v06] DM6 Firmware Update Installer for Windows. Updated 04.26.2012 Fix'dYa
8/4/2014 1:50:34 PM • Alesis DM6... • Answered on Aug 04, 2014
Can I use a 12V adapter to power the 9V output for my Alesis DM6?
No, it will work for some time, but will eventually overheat and cause damage. Spend the $10-20 and have piece of mind.
7/26/2014 11:58:04 AM • Alesis DM6... • Answered on Jul 26, 2014
0answers
Very low volume on all drums.
I don't think there is anything wrong, it has a very low line level output intentionally. This is to minimize distortion to an amp or mixer. Mine is the same and also a different brand. It is actually made so you could play it through a stereo without damaging it.
3/8/2013 4:12:06 AM • Alesis DM6... • Answered on Mar 08, 2013
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
1/11/2013 3:46:36 AM • Alesis DM6... • Answered on Jan 11, 2013
2answers
I had just recieved a brand new DM6. Upon setup
THERE IS A TINY SWITCH ON THE BACK OF THE MODUELETHAT MUST BE SET TO PAD , IF IT IS IN THE WRONG POSTION YOU WILL NOT GET ANY SOUND OUT OF YOUR KICK DRUM
1/11/2013 3:42:03 AM • Alesis DM6... • Answered on Jan 11, 2013
No sound from bass drum
MAKE SURE YOU DIDNT TURN OFF THE TINY SWITCH IN THE BACK OF THE MODUELE
1/11/2013 3:35:24 AM • Alesis DM6... • Answered on Jan 11, 2013
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
12/17/2012 9:51:07 AM • Alesis DM6... • Answered on Dec 17, 2012
When I hit my dm6 dual zone pad in the middle, i get no sound. only on the rim
it going to senser problem open clean and try
5/18/2012 9:24:31 AM • Alesis DM6... • Answered on May 18, 2012
Alesis DM6 electronic drum kit module sound
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
5/8/2011 1:47:16 PM • Alesis DM6... • Answered on May 08, 2011
Have the alesis dm6
Two things:
Check that cables are seated, especially the one at the main module.
Second, look for a setting for "Local Control" in your user's manual; That setting should be "On" to accept the triggers from the pads.
1/12/2011 5:10:51 PM • Alesis DM6... • Answered on Jan 12, 2011
Alesis Midiverb II 16-Bit Digital Effects Processor. I have an auto reset problem.
Question edited for full 'make model (what it is)'. Help in the video perhaps? Overload? https://www.google.com/search?q=alesis+midiverb+auto+reset+problem ..
11/10/2023 7:49:34 PM • Alesis Music • Answered on Nov 10, 2023
Alesis DM6 Electronic Drum Set Logo
40 questions posted
Top Alesis Music Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Alesis Music Expert? Answer questions, earn points and help others
View Most Popular
Alesis Music
  • Alesis Music
Most Popular Question
very low volume all drums
  • Music
