I want to know what ink for my machine
The Kodak 5300 uses the #10 cartridges. See http://www.staples.com/EasyShare-5300/cat_CL209209
SOURCE: Kodak Easy Share 5300 Printer
Please consider checking the new ink cartridge expiry date and the replacement is same model with the old one. Now, when replacing the old one please follow the proper procedure like some models uses software application in doing so. Try cleaning the nozzle procedures for unclogged ink-paths. If still persist you may need to replace the printer head. Otherwise, check the contact also between the ink and tray contactors. Hope this will solve the problem.
Best regards,
Rosener
SOURCE: kodak easy share 5300 -
The first thing you should try is running a printhead cleaning using the kodak software or from the local user interface on the printer. from the printer press the [menu] button. press the down arrow untill Clean Printhead is highlighted. press the [OK] button. Select "Deap Clean" and press [OK]. If this does not work you can mannually clean it. You can search online for how to clean inkjet printheads. I use distilled or de-ionized water and a LINT-FREE cloth. Dont use paper towls or anthing that could leave lint behind and clogg the nozzels. when you wipe the printhead make sure you only wipe in the direction of the nozzels, with the grain. Do not use a circular motion. You want to wipe from the front to the back or back to front of the printhead. Not left to right. I hear windex works as well but i have never tried it. Do some research online and use you best judgment. If none of this works you may have to contact kodak and see about getting a new printhead, they dont sell them sepeartly.
SOURCE: new ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you
changed the ink cartridge was bad. There is a known issue that when you
put in a new ink cartridge when the printer is in the error state
"COLOR INK
EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the
new ink cartridge so you will continue to have that error.
So to fix
your problem Open the access door and Remove the ink cartridges. Then download and install
the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank
and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
SOURCE: my kodak easy share 5300 has printing issues. I
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
SOURCE: HAVE PROBLEMS WITH MY KODAK PRINTER. EASY SHARE
you need to reset your printhead and check again
