Wile it was working i herd a small noise but the amp still work an fan dont
SOURCE: Crown CE1000
Hi waveybnc
The fan has failed, or is clagged up with dust. Remove it and clean it first. But best to just replace it. They are not that special and there is not alot that stops them from working. You can get a replacement device for the amp from Crown direct, or once you know its dimensions and power requirements, from here.
Thanks for using FixYa. Please rate my advice to you here as FixYa if it helps you.
regards
robotek
SOURCE: Should the fan run when my crown ce1000 unit is
It runs in response to certain thermal conditions.
SOURCE: fan running
This is a very sophisticated amp and it will turn the fan on at various speeds when it feels the need for it. Of course, if it's running REALLY hot, going into thermal protection and/or posting a fault you might take a look at it to see if it CAN turn (no obstructions).
Testimonial: "Thanks for the help that explains a lot."
SOURCE: CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Testimonial: "APPRECIATE THE HELP"
SOURCE: Crown CE1000 and CE2000 both clipping with low signals
for some reason channel one of one of our amps started clipping. i first noticed it with the drum kit but it slowly moved to the vocals as well. i haven't noticed this issue before today. what do i need to adjust to keep it from clipping?
