Elna Xplore 8600 Computerized Sewing Machine Logo
S
Sherri Hennagan Posted on Sep 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Elna problems my machine will not read the card it shows me a picture of turning off/on button and shows removing the card adapter devise. how do I get the machine to read the card
Danny Kuhlmann
Level 3:
  • Elna Master 1,443 Answers
  • Posted on Dec 05, 2015
Danny Kuhlmann
Elna Master
Level 3:
Answers
1443
Questions
Helped
262400
Points
4794
Power the machine down and unplug and let set for 30 mins then try again, if that doesn't work then will have to be repaired
I have an Elna 860. Trying for the first time to download new embroidery images. I have a new sd card. The hourglass just keeps spinning. It’s been hours. What should I do. It says to not turn machine off...
It should have worked in a few minutes.The SD card could be faulty or incompatible with your machine Turn it off, wait 15 seconds then turn it on again. This will not cause damage to the machine.
SD cards should be inserted or removed with the power off. They are not like USB drives which can be inserted with power on.
Your machine uses USB drives not SD cards according to the manual, are you using an adaptor?
If it still doesn't load after 10 minutes, there is a problem with either the SD card or the machine. Try the SD card on another Elna 860, perhaps at the dealer's shop, to prove it is ok, then ask the dealer to load the designs into your machine while you watch.
I have an Elna 6004. It does some embroidery (letters, small symbols). When I go to use the letters, not all the lines of stitching line up and it does not make a clean letter. How can I fix this?
https://www.manualslib.com/manual/912164/Elna-6004.html?page=16#manual
Try adjusting balance... see page 14.
Elna International Corps. SA
When pattern "8" is sewn with the feed balancing dial D at the normal setting mark (?) the
sewn pattern should be as indicated in the mark 0 in the following figure.
1. Set the adjustable pattern mode.
(Turn on the power switch while pressing the reverse button. Choose pattern 8
within 2.5 seconds. Display screen should read "CHECK PATTERN 8").
2. Set the feed balancing dial at normal setting mark (?)
3. Depress the controller. (Eight patterns "8" will be sewn and stop automatically).
4. Remove the base. (See page 2).
5. Adjust the stretch stitch feed balance by turning the adjusting screw D in direction A or B.
6. Attach the base (See page 2)
Note: If you know the position of adjusting screw C, this adjustment can al so be made by
removing only the oblong metal plate on the base cover.
I have an old Elnita 130 sewing machine with no manual. How to I thread it? It appears to work but shows signs that I did not thread it correctly.
elna make elinta machine and a 140 is the same threading as a 130
try entering the sites as most I go to require an account ( free) to procedure to read or down load and that process would be better for you
I went google and typed in--user manual for elinta sewing machine model 130-- and the sites show 130, 140 and more so select a site and go from there
thee is also a www.youtube.com>watch that runs for 1.29 and shows how to thread an old elna sewing machine
you might pick up a clue from that film
How do you thread an Elna elnita 244 sewing machine?
This may help:
Elna Elnita 225 Sewing Machine Threading Diagram
Consult your owner's manual. If you don't have one, search the internet for:
Manufacturer + Model + the word "Manual"
After I "undid" winding my bobbin, the electronic display still showed the symbol for winding bobbin and the machine will only sew straight. None of the other buttons like back stitch or change stitches...
are you sure you've moved the bobbin winding mechanism back to the right spot? if its still pushed over against the bobbin spool holder it may be stopping the normal functions from working. If that isn't the problem then it may be something for the tech at the Elna dealers.
My Elna 6005 turns on, but the mode buttons don't work at all. What can I do to fix it?
Check the "Twin Needle Button" It will interfere with decorative stitches.
1helpful
How do I oil an Elna 1010? Instruction manual says to take cover off and oil where arrows appear on illustration. But there is no illustration that shows this inside the machine after cover is taken...
For oiling the machine you need to look at the picture on the link below. The oil points are the red arrow.
Or you can get the manual on the lin kbelow page 35 will show you.
http://www.scribd.com/doc/3714472/Elna-1010-Manual
Good Luck
Nov 01, 2010 • Elna 1010
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
