Stove top works. Clock works. Everything works except for the broiler and oven.
SOURCE: neither the broiler nor
Check this out:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Good Afternoon friend, thanks for your post!
I see that your oven and broiler will not work on your Frigidaire range. It could be possible that your elements are bad or the thermostat may have shorted. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to have a professional technician come out to pinpoint the issue within your range. Best of luck! -Matt
