20 Most Recent
Frigidaire Gallery 30 Slide-In Electric Range White FGES3065KW Questions & Answers
Bad Electric Cooktop Dual Element Switch
Our Frigidaire Gallery electric cooktop dual burner would not work when either the single or double mode was selected. I did not have the electrical schematic available to use for troubleshooting the switch and initially was not certain if the switch or heating element was bad.
In thinking about the situation, I deduced that the problem was most likely the switch being bad as it was highly unlikely that both elements of the dual element burner would be bad at the same time. I ordered a new switch, received it a few days later, and replaced it in about 25 minutes. Upon turning power to the cooktop on and trying the new switch, both elements of the burner worked as expected.
Our Frigidaire Gallery induction cooktop is 'locked'. How to unlock?
Press and hold the keypad with the padlock icon until you hear a beep. This should be about 3 seconds. This will toggle the lock on and off. I used the documentation for the Frigidaire FGIC3067MB to check this. On this model, the lock keypad is to the left of the Keep Warm keypad. https://www.frigidaire.com/Kitchen-Appliances/Cooktops/Induction-Cooktops/FGIC3067MB/ . The manual is here: http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205604en.pdf . The control panel is shown on page 5 and the lock function is shown on pages 6 and 9.
I hope this helps.
Burner won't turn off. stays in simmer mode
Good Afternoon Judy, thanks for your post!
From what you have described the burner on your Frigidaire cooktop will not shut down and continues to run in simmer mode. I would suggest performing a reset on your cooktop and you can do that by disconnecting power from your cooktop for at least ten minutes. If that does not help alleviate your situation you may need to have a burner switch or control panel replaced and that is not a simple DIY job. If any electrical components need to be replaced I would recommend contacting a professional technician for proper repairs to be completed. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -OOS
How do you remove the control panel on a slide in glass top frigidaire stove model CFES367DC2
Hey Tamara webber, thanks for your inquiry!
I see that you would like to remove the control panel on your Frigidaire range, CFES367DC2. . Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree and please do not hesitate to reconnect. -Matt
Have a gas cooktop that clicks even when the knobs in are in the off position
Good Afternoon Hon,
I understand that your Frigidaire gas cooktop, model# FGC30S4ASA, is clicking even when the knobs are in the off position. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and listen for the clicking with the burner knobs in the off position. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
