Need to know the mounting hole diameter before ordering a replacement antenna. Thanks!
SOURCE: Antenna
Radio Shack carries various replacements. Make sure you know how your broken one mounts because they can look the same, but there may be a variation that will prohibit you from connecting it. If you can, take the broken one with you to match up. If they do not have it, check with a local electronics shop. They may also have a replacement for you.
SOURCE: Kenwood LPS 5000D
Hi cw10k
Thats odd. The only passive radiators I have seen over the years have been the same size as the bass driver. They need to be this way to provide the correct tracking of the bass driver. Your speakers sound more like a a 3 way system that may have been modded. Unfortunately they pre-date the internet by the looks of it :) I cant find any info for them, and from my recollection. Kenwood never made anything notable in loudspeakers. I suggest checking the crossover of the speakers to see if they look original, or if indeed they are 3 ways. If there is only a capacitor to the tweeter, then they were never meant to be performance loudspeakers,and probably came with a system of sorts. Keeping in mind the cost of replacement drivers to do upgrades to this sort of gear, may make them uneconomic to repair or upgrade. In Australia(they do deliver world wide) you can get passive radiators from Speaker Bits
Got any thoughts on that. :)
regards
robotek
SOURCE: broken antenna
The Sony part number is: 175422611 and the part is available for $15.95 from tritronicsinc.com or any other Sony parts distributor.
Dan
SOURCE: I purchased a Bosch PB10-CD Radio/CD Boombox and
Go here they are about 3bucks eReplacementparts.com
