Dryer stars up fine, runs heating for 2 min. - flame goes off digital time display goes to 1 (Cool down mode). High temp thermostat OK,gas coils OK. What is a door circuit failure (error code 3), and sensor bar (No wet cloths - error code 10)?
SOURCE: Maytag Atlantis MDE6200AYW will run, but no heat
Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
SOURCE: Dryer will run in cool down mode,but not in any other.
Hi!
Please check the following---
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please accept this solution and ask for any clarification.
Thanks
Rylee
SOURCE: I have a Neptune Gas Dryer MDG300AW and the flame goes out.
Well, first of all, the flame is not supposed to be continuous... it cycles on and off during the dry cycle because it staying on would incinerate your clothing. However, there are magnetic coils that do often go bad and cause the valve to stop opening after the beginning of the cycle... so you get a flame in the beginning, but if you were to sit there for 5 minutes with the dryer running, you would find that the flame stopped lighting completely.
They are pretty easy to replace... you will have to unscrew the little plastic pieces from the inside edge of the door, and unscrew the hinges and remove the door, then pull the front panel off (pull at the top).
Of course... UNPLUG before opening any appliance.
here's a picture of what you are looking for... they are completely outside the gas line, so changing them is very simple and doesn't require any handling of the gas. they are held on with a small metal plate.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500-%3d%3dd563888i3479&PartID=3479
SOURCE: Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
