Search for the video's name and delete it. Or... search for all videos saved between ___ and ___ dates and select the correct one from the search results.
If you want to delete a video from Facebook, First sign in your account and then click on your username on the upper right corner of any youtube page, By clicking drop down menu will open. Click on "My videos". Your videos section will open, tick the video you wish to delete. After it click on "delete option" under the my uploaded videos section. Video will be deleted. For clear picture the procedure to delete you tube video in shown in the given video.
I hope this solution helps you! Thank you for using FixYa!
No worries, you can recover deleted videos from Sony handycam with a professional data recovery software. Connect the handycam to computer, and then see whether it shows as a mass storage, if not, you need to take out the memory card or hard drive and then connect it to computer. You can then use data recovery software to get back deleted videos.
just browse the video in the camera in the view mode..and select the one you need to delete ..and options ..and delete ..it also have the option to multiple delete .. or ..if it is connected to a computer ..and it has a card ..and the movies are on the card ..just look for the card as a removable device in my computer folder ..open and delete what you don't need.. also in the main menu ..at the storage ..it is available the delete and format card and internal memory ..formatting them will erase all the videos on camera
You can recover the deleted videos provided that the data are not overwritten(if you continue using the camcorder, it might).
Deleting files(like videos or photos) from camcorder is just like clearing the recycle bin or Trash on your comptuter. The data itself isn't deleted, just the area containing the deleted data is also now marked as free space so it is available for any new data to be written there instead. The REAL data is still there. As a result a simple delete won't make your videos erased permanently.
Then you need opt for a third party data recovery software.
Install the program on your computer (choose the right version based on the operation system you are running), then connect your camcorder (memory card or HDD) to the computer and start to recover your deleted videos. I am sure you can operate the recovery on your own. Good luck.
Deleting files from camcorder is just like clearing the recycle bin or Trash onyour comptuter. The data itself isn't deleted, just the area containing the deleted data is also now marked as free space so it is available for any new data to be written there instead. So a simple delete won't make your videos erased permanently.
As a result, you have chance to retrieve those deleted videos as long as the video data on your camcorder(memory card or hard disk) are not written over. And the best way is to try some video recovery software, recommended Asoftech Data Recovery as it helped me before, the program can also recover photos and music.
First of all you need to install the program on your computer, then connect your camcorder (memory card or HDD) to the computer and start to recover your deleted videos.
When files are deleted they still remain on camcorder hard drive and can
be recovered, unless they have been overwritten by fresh data.
The only thing to do so run a data recovery program
to see what can be recovered. The only program I have tested is
asoftech data recovery software and it had done the job well. download
the data recovery from http://www.asoftech.com/adr/
Select the drive where your files were deleted and then do a deep scan. It will find your deleted files.
to delete you videos
1. Go to 'My Computer'
2. Go into your iriver e10 (removable disk)
3. Go to the folder 'Videos'
4. Highlight the video you want to delete
5. press the Delete key
6. empty the Rubbish bin
7. you have deleted a video!
Hey all, I had the same problem after deleting video on windows explorer. I couldn't figure it out untill I plugged camera into computer and opened files using windows media player. The video I had deleted came up in the playlist. I went to 'open from location' (right click while on the video tag line) And it tookme to a folder named 100video. There was the video I had deleted. So I deleted it from there while still hooked up and now my camera reads 60minutes again. Try it. Good luck
