Question edited for clarity and spelling of maker 'atvia' to 'Ativa'.
If it is only running in reverse the most likely cause is a faulty switch as the switch just reverses the polarity of the power to the motor. Also check that nothing is covering the proximity sensor in the throat of the shredder.
The shredder will only constantly run in the "Reverse" mode. The trigger located in the center of the feed entry slot, which activates the shredder, may be blocked. To clear it, you would need to insert an index card or file folder (i.e. rigid paper or cardstock) in the center of the feed slot and apply force.
I used to have an old Holden that did that. On the side of the gearbox were 2 levers that changed between gears. Sometimes if I was a bit quick on changing gears , it used to lock into 1st and reverse at the same time. By using a shifter spanner, I would crawl under the car and manually move 1 gearlever at a time until they clicked into the correct position. You may have the same problem where the gearbox has stuck in 2 gears. Have a play with the shifters while someone moves the gearlever to see if it will drop back into its correct position.
Probably the reverse mechanism has stuck. Only suggestion may be working the lever manually to see if it frees up. Other than that, it would need service or replacement.
It can be issue with gears or problem with transmission and needs to be rebuilt. Also get the tranny fluid checked. If it\'s low, then such problems occurs.
To troubleshoot these types of issues, check the actual solved problems with these types of issues.
There are solved help links provided below: -------
Click the link below and go through the details and diagrams to troubleshoot the problem: -----
2003 Lexus RX300: Transmission Fluid Burnt Brown and not Shift to reverse?
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
